List of roland mt-32 compatible hardware?
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby shiozaki » 2017-1-28 @ 15:23
seems to be a few different models that work and im unsure what are the ones i should be keeping an eye out for.
mt-100 cm-32l, cm-32p sc-55, sc-55t, sc-55mk2? do these work, what ones are worth buying?
shiozaki
Re: List of roland mt-32 compatible hardware?
Postby Dominus » 2017-1-28 @ 15:38
The CM64 is also worth it. CM-32l and CM-64 have extra sfx that some few games (Ultima Underworld - flowing water sfx) use. The SC-55 and the CM-32p are *NOT* fully compatible if at all.
User avatar
Dominus
DOSBox Moderator
Postby shiozaki » 2017-1-28 @ 15:43
thanks for the help what about the SC-88/ST PRO? there are so many.
shiozaki
Postby firage » 2017-1-28 @ 15:45
Don't forget the ISA card, LAPC-I.
User avatar
firage
Postby Dominus » 2017-1-28 @ 15:46
Yeah, I always omit that because I'm not interested in those legacy isa things :)
http://www.marshalltradecorp.com/coDe/o ... cm32l.html
User avatar
Dominus
DOSBox Moderator
Postby elianda » 2017-1-28 @ 15:57
You should consider adding the Roland RA-50 as well.
Youtube Channel
User avatar
elianda
Postby gdjacobs » 2017-1-28 @ 17:51
The RA-50 uses LA, but does it have compatible waveforms?
User avatar
gdjacobs
Postby CHiLL72 » 2017-1-31 @ 10:38
And what about the CM-500?
Looking for Roland MIDI modules or cards? http://members.home.nl/c.kersten
User avatar
CHiLL72
Postby jheronimus » 2017-1-31 @ 10:41
elianda wrote:You should consider adding the Roland RA-50 as well.
I would love to see some confirmation on this. I've been looking for a good deal on MT-32 for almost a month now. RA-50 seems to be almost 3x cheaper.
Edit: So far have only seen one person comment on the issue here and here.
Pentium III 800, 512 MB RAM, Voodoo 5 5500 AGP, SB Live 5.1 Platinum, SB AWE32 CT3990, Gravis Ultrasound Max rev 2.1
User avatar
jheronimus
Postby bjt » 2017-1-31 @ 11:29
As you saw in the other threads, the RA-50 doesn't support the All Notes Off command which leads to hanging notes in some games.
You can work around it using SoftMPU, but only for real-mode games.
I guess most games that are best on MT-32 are real-mode.
User avatar
bjt
Postby Dominus » 2017-1-31 @ 11:30
So, please consider the RA-50 :)
User avatar
Dominus
DOSBox Moderator
Postby gdjacobs » 2017-1-31 @ 14:50
bjt wrote:As you saw in the other threads, the RA-50 doesn't support the All Notes Off command which leads to hanging notes in some games.
Would the HardMPU card also support that feature?
User avatar
gdjacobs
Postby RJDog » 2017-2-01 @ 00:43
gdjacobs wrote:Would the HardMPU card also support that feature?
Yup sure is... ab0tj is obviously thr authority on that, but it has 3 or 4 options (via command line config utility) one of which is the all-notes-off RA-50 fix. The code is actually shared with SoftMPU...
RJDog
Return to Sound
Who is online
Users browsing this forum: Ozzuneoj and 2 guests
