Covox Sound Master II Driver Installation
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby boxpressed » 2017-1-31 @ 04:19
I recently acquired a loose Covox Sound Master II card. I downloaded a set of drivers off Driver Guide that look like they should work. It seems that the install program expects to be launched from a floppy, so I copied all the files to a floppy (A: drive).
The install program seems to run okay at first; it asks which is the "source" drive (A: or B:) and which is the "installation" drive (C: D: or E:).
Once I select A: and C:, respectively, I'm taken to a menu where I can select "Install."
I'm asked if I want to install "programming files." I select Yes.
I'm then asked to insert install diskette. When I select "OK," the menu briefly flashes but returns to the same state.
Obviously, the program is expecting a program that's not on the diskette. Or maybe it is expecting a diskette with a specific volume name (like early Sound Blaster installations). Same thing happens whether I say I want to install the programming files or not.
Anyway, if anyone knows what's going wrong, I'd appreciate hearing about it. Thanks!
User avatar
boxpressed
Re: Covox Sound Master II Driver Installation
Postby boxpressed » 2017-1-31 @ 16:28
Ah, user error. I think that the Driver Guide files were already decompressed (it is basically the DOS directory), so there was nothing for the install program to decompress.
User avatar
boxpressed
Return to Sound
Who is online
Users browsing this forum: No registered users and 5 guests
