First post, by cj_reha
I have an AWE64 CT4520 card here I am using for my Windows 98 box. It's recognized in 98 SE, plug and play drivers are installed and it works fine for Wavetable MIDI.
Unfortunately after a restart it defaults to Sound Blaster 16 mode (16-bit audio mode) for MIDIs. I have found removing the drivers and having 98 reinstall them works for a single boot.
I also found disabling the 16-bit audio driver works, and it goes back to Wavetable MIDI, but it no longer has volume control and cannot play WAVs.
Is there a way I can make it default to Wavetable MIDI for MIDI files, and 16-bit audio for WAVs?
Thanks.
Reply 1 of 2, by Jorpho
Can you be more specific about exactly what you are seeing?
If you are loading a soundfont and then restarting, then you will have to reload the soundfont again.
Perhaps your BLASTER environment variable is being set incorrectly?
Reply 2 of 2, by swaaye
Yeah I'm not sure I understand what he's describing either. AWE64 basically works as a SB16 + EMU Synth. Is the synth disappearing after reboot, causing Windows to use the SB16 portion's FM synthesis instead? How about some screenshots of device manager before and after?
