First post, by alexsydneynsw
- Newbie
Hello,
I have a Sound Blaster 2.0. When I run C:\SB\TEST-SBC.EXE I get an error 0108 after a successful DMA test. After DMA test program quits to DOS. Anyone encountered this and have ideas what this error means?
1) I used this driver pack to see this behavior
2) I tried installing this driver pack and installation failed because it couldn't see the card at DMA 220h and DMA 240h after jumper change.
3) I tried to set IRQ jumper to both 5 and 7 - same error.
4) I tried Monkey Island EGA in Adlib mode and I tested the non-MIDI sound In the PARROT application from the SB folder and both MIDI and regular sound seem to work fine.
5) I have another joystick port on an I/O card I use, so I removed Sound Blaster's joystick jumper.
6) I use a VLB I/O card and I think it could be a culprit, so I bought an ISA card on eBay and am still waiting for it to arrive.
7) I use 160W brick and Pico PSU as well as AT->ATX converter with -5V
Photos of the card and the program output up until error.
