First post, by oeuvre
- l33t
I have a Yamaha YMF719-S and after installing all my drivers (video, sound, network in that order), Windows for Workgroups 3.11 would refuse to run. It would run fine if I did win /n but if I ran it regularly, I would get a "Not enough extended memory to run Windows." This was with QEMM and 635K conventional free and the rig has 64MB RAM so I thought something fishy's going on.
The Softhsynth driver for the card was causing the error. Go into SYSTEM.INI and remove the DEVICE=VSGM.386 line. Go to the Yamaha line and change the 0's to 1's for these
[Yamaha]
CPLMPUBoth=1
DelSoftSynth=1
Hope others find this helpful.
