First post, by m5215tx
I have Win 98SE and Win ME systems that are configured with YMF724 based sound cards. I am considering replacing the YMF724 cards with Sound Blaster Audigy LS (SB0310) sound cards. Would this be a good upgrade from the YMF724 cards?
Roland MT-32 (old), CM-32LN, SC-55, SC-88VL, MT-120, SD-35, SD-20, SD-80, SD-90
Yamaha TG100, TG300, MDF2, MU15, MU100, MU2000EX + PLG150-DR + PLG150-PF + PLG150-VL
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
Reply 1 of 5, by gdjacobs
If you're doing DOS gaming or prefer XG wavetable synthesis, no it isn't. If you're running games that support EAX, yes it is.
Reply 2 of 5, by m5215tx
I am not doing any DOS gaming on these systems and I don't think I have many games that support EAX. I assume then with no DOS and little EAX both of these cards are about equal.
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
Reply 3 of 5, by gdjacobs
The Audigy can output higher sampling and bit rates, but in reality that makes virtually no difference.
https://people.xiph.org/~xiphmont/demo/neil-young.html
Reply 5 of 5, by m5215tx
derSammler wrote:
Why are you considering replacing the YMF724 cards at all?
I know the YM724 cards are older than Sound Blaster Audigy LS ones so I was wondering if I may get better quality/depth/complexity in the audio with the newer cards. It seems some of the primary features of the Sound Blaster Audigy LS will not be used much for me. I have a pair of great quality speakers for stereo but no speaker setup for a surround sound arrangement. I guess I will install the Audigy LS cards and see if they sound better for standard stereo use. If they don't then back to the YM724 cards I will go. I was just wondering if anyone had any direct experience with both of these cards in a W9x environment to give me a performance comparison between each of them.
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
