Which sound card is better for a 486 DOS PC? ES688FC, ES1898C PnP or YMF718-S PnP
Discussion about old sound cards, MIDI devices and sound related accessories.
Re: Which sound card is better for a 486 DOS PC? ES688FC, ES1898C PnP or YMF718-S PnP
Postby jxhicks » 2017-5-15 @ 19:38
Not that I found. There were some files labelled Midi mapper in the Windows 3.1 install files, but I never tried Windows 3.1 on that machine. ESSCONFIG for DOS only seems to have MPU-401 settings for later chips, but not the 688.
User avatar
jxhicks
Postby gdjacobs » 2017-11-20 @ 04:30
Appiah posted a driver package with the MPU TSR onboard a little while ago. HTH.
http://www.vogons.org/viewtopic.php?f=5 ... 60#p606494
User avatar
gdjacobs
Postby appiah4 » 2017-11-20 @ 08:58
I tested the TSR with an ES688FC and can confirm it loads. I did not get to try the midi out though as the system had other issues with the DMA modes.
A500:Rev6|512K+RTC|ACA500+|HxC/df1|C1084S
1994:PCI597-1|P133|32MB|Trio64|ES1868/S2
1997:S1573S|K6-2/400|64MB|M220|V2-SLI|CT4500/32M
2000:GA-BX2000|P3-700E|256MB|GF2GTS|MX300
DELL:GX110LP|PIII1000|512MB|G450|ES1938S/X3M
User avatar
appiah4
Postby jxhicks » 2017-11-21 @ 17:30
gdjacobs wrote:Appiah posted a driver package with the MPU TSR onboard a little while ago. HTH.
viewtopic.php?f=5&t=34088&hilit=401at&start=9760#p606494
Awesome, thanks to you both.
User avatar
jxhicks
Previous
Return to Sound
Who is online
Users browsing this forum: carlostex, SierraGamer and 2 guests
