First post, by SaxxonPike
- Member
All cards based on the OPL3-SAx that I've seen have a 33.8688mhz crystal on them, which makes sense for the typical 44.1/22.05/11.025khz sample rates. But some of them have a 24.576mhz crystal, and some of them don't. These would more often be used to clock 48khz sampling rates.
The datasheet for the OPL3-SA3 for example doesn't say anything about these clocks besides the information given in the pinouts for each package.
For those that have had extended experience with these cards, what do you make of it?
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
