SB Live VxD vs WDM
Discussion about old sound cards, MIDI devices and sound related accessories.
SB Live VxD vs WDM
Postby psychz » 2017-8-03 @ 12:48
So I have this P4 s423 build with a SB0060 Live Value inside. I'm running Windows ME with the unofficial service pack 2.02. The "Sound Blaster Live! Install (VXD 4.12.01.0905 + WDM)" image from VogonsDrivers thought it would be wise to install the WDM drivers, didn't even ask. While the card worked, I would get huge lag and framedrops in Heavy Metal FAKK2 and Thief Gold. By manually updating to the 09/2001 WDM drivers ("Sound Blaster Live! Value/PCI 512/5.1 Sept 2001 WDM", VogonsDrivers) the situation improved, the framedrops reduced, but not dramatically. Setting the games NOT to use HW sound acceleration/EAX, they were running silky smooth. Was going to keep the 09/2001 WDM drivers, but when I tried to play Jazz Jackrabbit and experienced choppy/stuttery crap instead of sound, I wanted to experiment a bit. Sure, this isn't a box for DOS games, but it gave me the feeling that something was broken. Today I uninstalled everything, installed everything from the CD and then forcefully switched to the VxD drivers. All stutter is gone, SB16 emulation works fine, EAX2 doesn't cause in-game lag and the whole toolkit of Creative still works. I have yet to encounter a single problem with them. Am I missing something (i.e. a setting), or WDM drivers aren't suitable for this kind of build? Any cons for using the VxD drivers instead of the WDM?
Stojke wrote:Its not like components found in trash after 20 years in rain dont still work flawlessly.
User avatar
psychz
Re: SB Live VxD vs WDM
Postby SRQ » 2017-8-03 @ 21:23
I've always used VXD on 98 and WDM on 2K/XP. Older games seem to only recognize the VXD for EAX- System Shock 2 in specific.
SRQ
Postby swaaye » 2017-8-04 @ 23:48
Early WDM drivers usually have problems. VXD is the way to go.
It's the same story with other Creative cards. Even the Audigy 2 has VXD drivers as an option and they are the best choice on 9x or Me ffor gaming.
swaaye
Moderator
Postby colpoz » 2017-10-25 @ 12:55
Which VXD driver version did you install? VXD 4.12.01.0905?
Does this version recognize the SB0060 natively without modding the .inf file?
RetroPc I: Asus P3V4X - PentiumIII 1000MHz - 256MB Ram - Geforce3 Ti 200 - SLI VoodooII 12MB - Aureal Vortex2 - HDD 80GB - Win98 SE
RetroPc II: Asus P5A - K6-2 333MHz - 64MB Ram - Geforce2 MX - Voodoo 4MB - Soundblaster AWE64 - HDD 13GB - Win95
colpoz
Return to Sound
Who is online
Users browsing this forum: Error 0x7CF, realoldguy23 and 5 guests
