First post, by muon
..Feedback path error
It happenned when i tried to run this command:
aweuitl /em:gm
The aweutil.txt file said
PROBLEM -- "Feedback path error" message.
CAUSE -- The hardware might be incompatible.
SOLUTION - Type AWEUTIL /S and press <Enter> to set your audio card to
Adlib compatibility.
I don´t understand that. I own a genuine AWE CT3670 ¿¿??
Any idea?
Thanks in advanced
Reply 2 of 11, by Malvineous
Also make sure you have the right software for the card you have. I have a couple of AWE cards that don't work with some versions of the software but do with others, so try some different versions of the utilities too. (And not always a newer version, sometimes they seem to have removed support for certain cards so you need an older version of the software instead.)
Reply 3 of 11, by jesolo
One possible explanation is that Aweutil requires a motherboard with non maskable interrupts.
You can try to enable memory parity error checking in your CMOS setup.
Otherwise, you will not be able to use Aweutil with the /EM switch
Reply 4 of 11, by derSammler
Err... what? No PC on this planet has *no* NMI. Also, you can not enable parity error checking without having RAM with parity (does not enable/disable NMI anyway). Both have absolutely no relation to AWEUTIL.
Reply 5 of 11, by jesolo
The guys over at Creative Labs seems to disagree with you, as evident from the attached FAQ that came with most AWE32 & AWE64 cards (refer Section A, no. 17).
    AWE32-FAQ.txt
    53.89 KiB
    167 downloads
    AWE32 FAQ
Reply 7 of 11, by muon
I think that's the point. The soft that I installed, was the AWE64 version.
I'll try with the original soft of the card
Reply 8 of 11, by jesolo
I have used my AWE64 software on my SB32 (CT3930) and AWE32 (CT3980) without problems.
It's usually a problem if you try to use the earlier version software on the later hardware but, give it a try.
Reply 9 of 11, by Kamerat
CT3670 is actually a Sound Blaster 32, not AWE and it's based on the same chipset as the AWE64.
I also got the same error after initializing my ESS Solo-1 along with my Sound Blaster 32 CT3620, maybe you got some resource conflict?
YouTube channel
Reply 10 of 11, by matze79
Have the same Problem loading Banks works fine on Windows but not on DOS, but i use a unusual Mainboard.
OPTI VLB Pentium - Galaxy V.
I also used AWE64 install CD.. and SB32.. maybe this wiill solve my Problems 😁
Reply 11 of 11, by egrabczewski
I'm no expert on this subject and I saw this post when Googling for a solution ...
I encountered the ERR014 error when running the AWEUTIL /EM:MT32 command in the C:\SB16 directory
(the SYNTHMT.SBK file is in C:\SB16\SFBANK. I assume this is where AWEUTIL is looking for it).
After a process of elimination I found the SOFTMPU utility in my AUTOEXEC.BAT file was causing the problem.
After commenting out SOFTMPU then the command AWEUTIL /EM:MT32 worked.
If I run SOFTMPU /MPU:330 /SB:220 /IRQ:5 /DELAYSYSEX after running AWEUTIL then SOFTMPU hangs.
If nothing else, this shows that this problem is not always caused by hardware incompatability.
NOTE: My system is: MS-DOS 6.21 and WfW 3.11 running on a MS-6156 motherboard with Pentium III MMX processor.
The SB card is a AWE64 CT4520.
