Opinions on Yamaha TG100 and Kawai GMega
Discussion about old sound cards, MIDI devices and sound related accessories.
Re: Opinions on Yamaha TG100 and Kawai GMega
Postby Shponglefan » 2017-10-03 @ 16:40
derSammler wrote:@Shponglefan: I guess the MU2000 can not be compared to the MU50/80. I only have the later, so I can't compare the GMega to a MU2000.
To my ears, the underlying instruments/soundset on the MU2000 and MU80 sound very similar. But the MU2000 does have a clearer, fuller sound.
I may do up some recordings of that MIDI on the Yamaha's and GMega just for comparison. I'd also be curious if your GMega sounds the same as mine. Given it is older hardware, I never really know what the true 'stock' sound should sound like.
MIDI module collection: Edirol SC-D70, SD-90 | Kawai GMega | Korg AG-10, NS5R, Triton Rack | Roland MT-32, CM-32L, CM-64, CM-500, SC-55, SC-88, SC-88 Pro, JV-1010, XV-5080 | Yamaha MU-80, MU-2000EX
User avatar
Shponglefan
Postby SuperDeadite » 2017-10-03 @ 16:48
Starting with the MU100, Yamaha replaced most of the old GM samples with new ones.
MU1000/2000 contain both sets of GM samples though.
You can switch to the old sounds by changing "MU100 Native" to "MU Basic" in the options.
But when using MU Basic, the 1000/2000 will still sound a bit better then the older modules
due to better audio hardware, especially if you are using the digital output.
Modules: CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, Dreamblaster X2
SuperDeadite
Postby Cloudschatze » 2017-10-03 @ 17:59
SuperDeadite wrote:But when using MU Basic, the 1000/2000 will still sound a bit better then the older modules
Similar to a comparison of an actual SC-55 with the "SC-55 Map" on later Sound Canvas units, there are enough tonal and effect differences between playback using the "MU basic" map on my MU100, and an actual earlier unit (MU50, MU15, DB50XG, SW60XG, etc.), that I find value in having both.
User avatar
Cloudschatze
Postby derSammler » 2017-10-05 @ 11:46
Today a Korg 05R/W joined my collection. :)
derSammler
Postby Cloudschatze » 2017-10-05 @ 15:53
derSammler wrote:Today a Korg 05R/W joined my collection. :)
Do yourself a favor and check for leaking SMD electrolytics in that unit post-haste. Korg gear from that period is especially notorious for this problem. Roland gear isn't immune either - If you have an SC-88, there's a fair likelihood that leaking SMD electrolytic capacitors are actively destroying circuit-board traces.
User avatar
Cloudschatze
Postby derSammler » 2017-10-05 @ 17:21
Yes, I know. Having lots of Amigas (esp. A600/1200), Macs, and other hardware, I replaced hundreds of those caps in the past. Checked the Korg already, the caps are still looking good. However, the unit seems to be broken anyway. It does not change the patches when in GM mode, making everything sound wrong. Demos won't play correctly either. Factory reset did not fix it. :(
derSammler
Postby derSammler » 2017-10-06 @ 11:28
Finally, an SC-88 Pro came in today. That's enough for now. :D
derSammler
Postby yawetaG » 2017-10-06 @ 14:48
derSammler wrote:Yes, I know. Having lots of Amigas (esp. A600/1200), Macs, and other hardware, I replaced hundreds of those caps in the past. Checked the Korg already, the caps are still looking good. However, the unit seems to be broken anyway. It does not change the patches when in GM mode, making everything sound wrong. Demos won't play correctly either. Factory reset did not fix it. :(
Check the Korg website to see whether they still have the patches and whether you can reload them over MIDI.
yawetaG
Postby derSammler » 2017-10-06 @ 17:04
yawetaG wrote:
derSammler wrote:Check the Korg website to see whether they still have the patches and whether you can reload them over MIDI.
Patches can be re-loaded from ROM, but that doesn't work. The unit is faulty, already sent it back to the seller.
Another unit I'm currently playing with is a StudioCanvas SD-20. That one is quite cool when used with DOSBox. All you need is USB, no MIDI and no PSU. Sound is also of very high quality, but quite different from SC-55/88 and the like.
derSammler
Postby derSammler » 2017-10-24 @ 19:23
So now I own:
  • Yamaha TG-100
  • Yamaha MU50 (for sale actually, since redundant)
  • Yamaha MU80
  • Roland SC-7
  • Roland SC-55 (GS)
  • Roland SC-88 Pro
  • Kawai GMega
  • Akai SG01K
  • Edirol SD-20
Still looking for a Korg to complete my collection.
So far, I'm quite impressed by the SC-7 (size, color [fits perfect to my Schneider AT Tower], clearness of sound), the GMega and the SD-20. The latter just sounds incredible with non-game MIDIs. I'm preparing recordings for my website, so stay tuned. :)
derSammler
Postby derSammler » 2017-10-31 @ 22:21
The first batch of recordings is online:
http://retro-net.de/midi/
All recordings were made using an ASUS Xonar DGX (105 dB SNR), midi module(s) set to factory defaults, and a GM reset before playback.
derSammler
Postby derSammler » 2017-11-02 @ 18:35
No comment yet on how awesome Lotus sounds with the GMega? Blows away even the Amiga 8-O
derSammler
Previous
Return to Sound
Who is online
Users browsing this forum: Danfun64 and 4 guests
