Low profile soundcard for win98 + SB16 DOS
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby Tmp2k » 2017-10-22 @ 08:56
I might try and build my retro rig into a compact case, so mATX + Low profile PCI cards. The Audigy seems to be the oldest creative card that comes in low profile, I can see Win98 drivers exist, but does anyone know about SB16 emulation in DOS? Is there a better choice?
Tmp2k
Re: Low profile soundcard for win98 + SB16 DOS
Postby PARUS » 2017-10-23 @ 21:57
It's good choice for SB16 emulation but not for SB Pro emulation. Second: you need to load EMM386. Third: your chipset southbridge must to support DMA. Fourth: the IRQ of PCI slot where you plug a card shouldn't be the same as IRQ of emulated SB16. Fifth: supported models are SB0090, SB0240, SB0350. What about others I don't know. Sixth: for SB0240 and SB0350 you need unofficial patch.
Now try if you still wish.
User avatar
PARUS
Postby BitWrangler » 2017-10-23 @ 22:39
I don't know about better, but I've seen ALS chipset cards in low profile. I think I've seen an ESS one too. The ALS you'd probably have to try a few until you found one whose hiss you could live with.
Basement full of ancient PC stuff, starting to go through it. Most recently toyed with DOS era stuff 15 years ago, so memory might be rusty. So what's this BitWrangler guy's deal ??? >>> http://www.vogons.org/viewtopic.php?f=25&t=56382
User avatar
BitWrangler
Postby Kamerat » 2017-10-24 @ 05:10
How well a PCI sound card works in DOS boils down to the chipset of the motherboard and the sound card you choose. Stay away from Intel chipsets other than BX/ZX/EX, the only exception are boards with PC/PCI (SBLINK) connector. VIA chipsets works well with ESS Solo-1 and Avance Logic ALS4000. SiS chipsets up to the SiS 962 southbridge seems to work fine with Yamaha YMF7xx PCI and Avance Logic ALS4000.
On the other hand you got PCI cards that relay on complicated TSR software like Sound Blaster (Ensoniq) PCI/Live!/Audigy and Aureal Vortex that also works on Intel chipsets up to the ICH5 at least. Also the YMF7xx PCI can gain better chipset compatibiliy by unsing a TSR called DSDMA but then you need to load EMM386 or similar and then you loose some game compatibility.
Maybe it's possible to modify one of Terratecs Solo-1 cards to fit inside a case intended for low profile cards as it's height is between low profile and full height. There's also a couple of low profile ALS4000 boards on Ebay any on my ALS4000 lot of the static noise could be avoided by muting the FM synth (it's actually a good OPL3 clone if you don't mind the noise).
User avatar
Kamerat
Return to Sound
Who is online
Users browsing this forum: silentw and 3 guests
