Soundcard very very quiet (not amplifying)
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby Almoststew1990 » 2017-10-28 @ 12:11
Hi everyone
I have a soundblaster live SB0100. I have been using it with no issues recently until today and suddenly I can't hear anything, unless I turn my speakers up very loud, and then i can hear windows noises and what not. So my card is outputting but not amplifying sound. Co-incedently I had just installed DirectX 8.2 but I hadn't had any sound for a while (was just on the desktop). Could my card be dead?
I have re-installed Windows 98 (I was going to anyway) and just got AGP chipset, Voodoo drivers, Direct X 7 and Soundblaster drivers installed (in that order) and I still have the problem. (I've just realised I needn't have installed the AMD AGP drivers as my voodoo 3 is PCI but I doubt that would cause the issue?)
Intel 4770K 4.4GHz | 8GB DDR3 2133MHz | AMD 390X | 750GB EVO SSD
Intel E8500 3.1GHz | 3GB DDR2 | Nvidia GeForce 645 1024MB | 750GB HDD
Slot A Athlon 800MHz | 256MB PC100 | Voodoo 3 2000 | SB Live! 5.1
User avatar
Almoststew1990
Re: Soundcard very very quiet (not amplifying)
Postby TOBOR » 2017-10-28 @ 15:54
Almoststew1990 wrote:Hi everyone
First the obvious. Check to see if speaker plug is in correct hole for your config? do the diagnostic speaker tests perform correctly? Any errors showing? Goog chance that the caps have gone bad causing the problem.
If the truth hurts, tough shit.
TOBOR
Postby TOBOR » 2017-10-28 @ 16:00
Run dxdiag and if it runs ok with no errors or freezing then the card could be bad. Try installing the last version of DirectX for 98 then try again.
TOBOR
Return to Sound
Who is online
Users browsing this forum: dreamblaster and 5 guests
