Sound Blaster 16 CT2740 Hanging note bug or not?
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby bjwil1991 » 2017-11-10 @ 16:23
I found a card online, the Sound Blaster 16 CT2740 which has the DSP version 4.11 and I'm trying to figure out if this card has a hanging note bug.
Hanging Note Bug - Vogons Wiki: This site doesn't have the card listed, so I don't know if it does or not. I did ask the seller to check and see if there's a hanging note bug.
The card has the CT1747 bus interface, so there is no Type 1 hanging note bug, but IDK if it has the Type 2 hanging note bug, or if it doesn't have that (that'll be the day).
C64, WheelWriter 10 Series II, Pack-Mate 28 Plus, K6-2/300, Pavilion N3350, iMac G3/600, Socket 370, HP Socket 478, 2x Inspiron 600m, Athlon 64, Dimension 4550 & E510, ThinkPad R40, Presario C700, ASUS X54C, Raspberry Pi B+, 2-3, Custom FX-6300
User avatar
bjwil1991
Re: Sound Blaster 16 CT2740 Hanging note bug or not?
Postby clueless1 » 2017-11-10 @ 17:46
I think this quote from the Hanging Note Wiki answers your question:
Affected are all Sound Blaster models with DSP revisions 4.11, 4.12 and 4.13.
User avatar
clueless1
Postby bjwil1991 » 2017-11-10 @ 18:14
clueless1 wrote:I think this quote from the Hanging Note Wiki answers your question:
Also, another quote from the Wiki:
Type 1 doesn't occur on cards with a CT1747 bus interface.
The card has the CT1747 bus interface (OPL3) and the card was manufactured in 1993. However, I don't see the card in the list of affected cards.
User avatar
bjwil1991
Postby jesolo » 2017-11-10 @ 18:35
The list on the Wiki page is not exhaustive.
This particular model will therefore only have the Type 2 bug.
However, as also mentioned, this occurs very rarely.
User avatar
jesolo
Postby bjwil1991 » 2017-11-10 @ 19:14
jesolo wrote:The list on the Wiki page is not exhaustive.
Guessing it's because if the song's soundtrack has a hanging note, the "Note off" command is often missed? I found another forum about different types of bugs: Sound Blaster 16 Bugs and Deficiencies Summary
User avatar
bjwil1991
Postby derSammler » 2017-11-10 @ 20:33
bjwil1991 wrote:Guessing it's because if the song's soundtrack has a hanging note, the "Note off" command is often missed?
Sort of. It does not really just affect the "Note off" command; every MIDI command can get corrupted randomly. But due to the way MIDI works, you only really notice it if a "Note off" command gets corrupted. Also, it will be more present the higher the polyphony of the MIDI module / wavetable is.
derSammler
Return to Sound
Who is online
Users browsing this forum: gdjacobs, nukeykt, SteveC and 1 guest
