Have a bit off an off problem with the AWE 64 Gold I have.
I'm using it with a 200MHz Pentium MMX, and with Freedos 1.2.
Burned a CD with drivers from this site, and installed those.
Spent quite some time on this, so won't bore with all details, but as it is now I have the following issue.
On all the games I have tried(they are all GOG versions) I can't get it to play music. It is just silence.
Soundeffects works fine.
The thing is that when running diagnose I also could not hear anything, but when installing the SimmConn with 32mb ram I ran CTCM and then diagnose would detect the ram, and play synthesized music,
and a new option for AWE syntesized music. Both test fine, and I can hear the music, but when loading games, I get no music again.
It looks like it plays, but no sound is coming out the speakers.
In Duke3d, I hear sound effects when testing, and silence when testing music.
So I think there is a problem when loading CTCM, but unsure wether it should load in autoexec.bat, config.sys or fdconfig.sys.
Another thing is that when running diagnose, and I try to save the settings, the computer will always freeze, and I need to push CTRL - ALT - DELETE to restart it.
Looks like it saves settings however.
