What MIDI sound modules do you enjoy listening to?
Discussion about old sound cards, MIDI devices and sound related accessories.
Re: What MIDI sound modules do you enjoy listening to?
Postby m5215tx » 2018-1-03 @ 14:34
K.A.R.R. wrote:here are the songs with latest sound canvas va 1.1.1
You are running a significantly older version of Sound Canvas VA. If I am not mistaken the last version that was released before Roland went to a cloud based Sound Canvas VA is 1.3.0 which is what I am running myself. I believe there are a number of bug fixes and improvements since 1.1.
Roland MT-32 (old), CM-32LN, SC-55, SC-88VL, MT-120, SD-35, SD-20, SD-80, SD-90
Yamaha TG100, TG300, MDF2, MU15, MU100, MU2000EX + PLG150-DR + PLG150-PF + PLG150-VL
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
User avatar
m5215tx
Postby K.A.R.R. » 2018-1-03 @ 19:27
are you sure with 1.3.0 ?
i am using the cloud version and it should be the latest :depressed:
could you take a look at your version number pls
https://picload.org/view/ddogdpaw/sc.jpg.html
my exact version is 1.11 S (build 1110 ) 64 bit
K.A.R.R.
Postby Falcosoft » 2018-1-03 @ 19:55
There is no such version of SC-VA as 1.3.0 so far. It's rather 1.0.3. The version of the 'offline' downloadable trial you can get from Roland is still 1.0.3.
https://static.roland.com/assets/media/zip/scva_win_trial.zip
In the meantime Roland has updated the cloud version so K.A.R.R 's version is newer than the offline one. You can find non-official offline versions like 1.0.6/1.0.7 on the net but they are 'modified' versions...
User avatar
Falcosoft
Postby K.A.R.R. » 2018-1-03 @ 20:29
Falcosoft wrote:You can find non-official offline versions like 1.0.6/1.0.7 on the net but they are 'modified' versions...
and with a roland cloud emulator you can run the sound canvas va offline without using roland cloud....
but i guess this is the wrong place to discuss it 8)
K.A.R.R.
Postby m5215tx » 2018-1-03 @ 22:48
Sorry my mistake K.A.R.R. As it has already been noted, I misread the version number I was running! LOL
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
User avatar
m5215tx
Postby K.A.R.R. » 2018-1-04 @ 04:16
np :happy:
seems roland doesn't release a changelog
so nobody knows what they changed.
(may be i'll ask roland if they have a complete changelog for all versions)
i only found a posting on the net with changelogs from 1.02 and 1.05
somebody said he got them from japan:
Ver.1.02
– Fixed the bug of not able to save the sound when in a DAW.
– Fixed the bug of not able to playback with correct sound map with certain data.
Ver.1.05
– Fixed the bug of some EFX going abnormal.
– Fixed the bug of System Effect “Delay”.
– Fixed the bug of EFX screen value displaying.
– Fixed the bug of GM/GM2 mode screen displaying and also the behavior
– Fixed the bug of Drum2 Part setting.
– Fixed the bug of display going scrambled on some DAWs.
– Fixed other minor bugs.
K.A.R.R.
Postby K.A.R.R. » 2018-1-06 @ 21:53
before i used roland sc va i used native instruments bandstand and papelmedia soundfont
i no longer own ni bandstand
but i still have the papelmedia soundfont
they sold sf 2007, sf 2008 and later sf final 10 years ago
(each for 20-30 € i can't remember exactly)
papelmedia no longer exist.
here the doom songs with papelmedia final xxl soundfont (xxl was the larger (1,3 gb) uncompressed soundfont)
doom 1 map 1
http://www76.zippyshare.com/v/DbFXDo1C/file.html
doom 2 map 1
http://www76.zippyshare.com/v/y2m6UDxA/file.html
K.A.R.R.
Previous
Return to Sound
Who is online
Users browsing this forum: No registered users and 6 guests
