OPL3LPT : OPL3 FM Synthesis on parallel port
Reply 200 of 212, by Jinxter
dreamblaster wrote on 2020-03-08, 13:40:
Jinxter wrote on 2020-03-08, 12:07:
Suggestion.
Sometimes i need to go to the back of the PC and press reset. Instead i start the opl3test which resets the OPL3LPT.
What about a reset util, or a parameter to the opl2test that only resets?
good idea
Wow that was quick. You already updated github with an oplreset.exe. Thanks. I have entered the oplreset.exe in my autoexec.bat
Check out my YouTube channel: Retro Erik https://www.youtube.com/channel/UCSUf7nCpwTgFbjGmcTYGZEQ
My collection: https://retro.hageseter.com
Reply 201 of 212, by Jinxter
The readme file states that you have to use EMM386 version 4.46 or later. I Tried the adlipt driver on PC DOS 6.00. With version 4.45 of EMM386. That did not work.
So then i copied the emm386.exe from a MS-DOS 6.22. I was surprised to se that PC DOS 6.00 had no objection to that.
So if you have an older DOS version on your retro PC, you probably don't have to upgrade DOS to a newer version. It is enough with the emm386.exe.
For me, this is important because i am trying to keep my Retro computers true to the time periode they were used.
Reply 202 of 212, by dreamblaster
Here's a new demo of OPL3LPT, running on IBM PS/2 Model 55sx, on youtube channel Retro Erik : https://youtu.be/bQZSTH5bQVQ
OPL2LPT, OPL3LPT, X2, S2, S2P, MCE2VGA, ... many projects !
Special vogons LPT bundle : https://www.serdashop.com/Parallel-port-retro-sound-bundle
Thanks for your support !
Reply 204 of 212, by matze79
Yeah opl2lpt rocks! Great Device!!!
Co2 - for a endless Summer
Reply 205 of 212, by Jinxter
matze79 wrote on 2020-04-11, 19:08:
It there any reason so choose the OPL2LPT over the OPL3LPT?
Reply 206 of 212, by root42
Jinxter wrote on 2020-04-11, 19:20:
Beautiful through hole chip of course!
YouTube and Bonus
80386DX@25 MHz, 8 MiB RAM, Tseng ET4000 1 MiB, SnarkBarker & BlasterBoard, PC MIDI Card + SC55 + MT32, XT CF Lite, OSSC
Reply 207 of 212, by appiah4
Price maybe, also authentic OPL2 if you want adlib sound.
Reply 208 of 212, by Jinxter
appiah4 wrote on 2020-04-12, 05:06:
Do they not sound exactly the same. Is not the only difference that the OPL3 has stereo?, and when using OPL2 games, will not the sound be the same?
Reply 209 of 212, by matze79
But it feels different!
Reply 210 of 212, by appiah4
Jinxter wrote on 2020-04-12, 11:59:
OPL3 has more voices, but is 100% backwards compatible. However, with Adlib/OPL2 you actually can't have the same amount of polyphony as OPL3, so it sounds completely different when playing chiptune music etc. as it completely skips some sounds.
Also, most sound cards featuring OPL3 have some kind of filtering going on that makes the resulting sound slightly different from the way an Adlib card does.
Reply 211 of 212, by cde
I have received and assembled my OPL2LPT and it is working very well! Thanks dreamblaster for the detailed instructions 😀 Also I got a few questions:
- Sometimes when I cold-start the PC the OPL2LPT will emit a sound or series of sounds. This isn't a real problem since it happens rarely and I can reset the OPL2LPT from DOS, but is this behavior to be expected or did I miss something about the assembly? Or could this be caused by the motherboard's BIOS (Abit KT7A) sending stuff over the parallel port?
- I tried to patch Monkey Island 1, and although the patch seems to proceed successfully (two locations were patch), I get no sound. OTOH the ADLIPT program will produce sound when the non patched MONKEY.EXE is run. Any idea?
- Are there particular noteworthy DOS games that make use of the OPL3 more advanced capabilities?
Reply 212 of 212, by dreamblaster
cde wrote on 2020-04-25, 18:59:
Yes it could be due to parallel port behaviour at bootup. The reset button or driver initialisation will resolve it.
no idea
Cybersphere has very nice OPL3 music
