First post, by Baoran
Anyone knows if there is any way to make YMF743 sound chip to work in dos games?
Reply 2 of 3, by Baoran
I just have not been able to find any drivers for dos. I boot a dos 6.22 floppy and I tried small games like commander keen 4 using just the floppy drive and none seem to recognize that there is anything adlib/sound blaster compatible in the system. I also tried setting standard blaster variables too.
Reply 3 of 3, by Kamerat
It doesn't require any drivers but you still need to initialize it, try the ones for YMF744:
Download from here:
http://device.yamaha.com/en/lsi/download/
http://vogonsdrivers.com/index.php?catid=39&menustate=51,35
Or a modified one compatible with more motherboard chipsets:
http://vsynchmame.mameworld.info/
The initializer is called SETUPDS.EXE.
YouTube channel
