First post, by metrox
Hi all, was wondering would the Sound Blaster Audigy 2 PCI Sound Card SB0240 work on DOS ? Also wondering if there are Win98 drivers for this card
thanks
thanks
I have the same issues.
Does this use the same driver CD as the 2 ZS?
If so I'd think you would be ok
chinny22 wrote on 2021-03-02, 10:49:Does this use the same driver CD as the 2 ZS?
I have that card and the 2 ZS, and the same drivers don't work with it. However, there is a driver CD that works well with the SB0240 and has both WDM and VXD drivers. I have it somewhere, let me find it first, and I'll upload it here later.
And to answer the original question, yes, there are DOS and Win98SE drivers for it.
