First post, by Pabloz
Yesterday i was testing a box i had with soundcards. Most of them were fine
tested lots of SB16, AWE64, SB32, and then i tried to test an AWE32 CT3670
no go, tried 2 different motherboards and nothing, when running the Install i always got an red error msg saying 220H not found, and nothing was found, and can´t continue the setup
then i exchanged it with a CT3600 and it worked right away and installed everything.
But this CT3670 which is very similar fails to be recognized.
I wonder if replacing all capacitors would make a difference, or changing the voltage regulator would save the card. Or i should just send it to heaven.
