First post, by static-
Has anyone gotten this to work, official from Roland? It apparently patches your MT-32 to make it work better for GM playback.
http://www.houseofsynth.com/roland-mt-32-to-g … version-utility
I've tried several methods of loading "MTGM.mid" to my MT-32rev0 but none of the midi music seems to sound any different (ex. doom).
I've tried MDF, MidiEX, dump, dosmid, and I do see the green led flashing on the mt-32. I also tried softmpu.exe with /SYSEXDELAY and that made a lot more green led flashing, but still no difference.
Did I miss something? I only loaded MTGM.MID as per the instructions
Reply 1 of 3, by Laukku
I've gotten a MTGM.MID to work by playing it with PLAYMID.EXE in DOSBox. (Here's a video of Trilby's Notes.)
See also: https://www.philscomputerlab.com/ultimate-rol … 2-tutorial.html (Includes playmid.exe)
My YouTube account, with miscellanous DOS game stuff: http://www.youtube.com/user/LaukkuTheGreit
Reply 2 of 3, by Falcosoft
You can also use FSMP for this. You do not even have to use MTGM.MID since the SysEx messages are extracted to MT32_GM_Mode.syx and you can set it as a default reset SysEx. This way you no longer have to worry about other MT-32 midi files overwrite the GM state by sending other SysEx messages. You can set it as a custom SysEx by right clicking the 'First Aid' like reset button -> Select/Send Custom SysEx -> MT32_GM_Mode.syx. Pressing the reset button sends the messages immediately but the messages are also sent before playback. An alternative way is that you copy the MT32_GM_Mode.syx file to the folder where your GM midi files are and rename it to 'Folder.syx'. Folder.syx file is loaded before playback for all files in the folder.
http://falcosoft.hu/softwares.html#midiplayer
You can elso test with FSMP more easily. You can check if loading MTGM.MID/MT32_GM_Mode.syx worked by pressing notes on the virtual piano of FSMP on Channel 1. Channel 1 by default is not assigned to any parts on MT-32 (only channels 2-10). But if loading is OK the new GM compatible channel layout 1-8,10 is set by the SysEx messages so you should hear Acoustic Piano 1 on channel 1.
Website, Facebook, Youtube
Reply 3 of 3, by static-
I appreciate your detailed answers, thank you!!
playmid.exe worked great, and I didn't need softmpu's help of /SYSEXDELAY
Falcosoft, FSMP looks amazinggggg++. When I finish setting up Win98 I'll certainly be playing with this. I do see your sysex files... and actually grabbed them to try.
I tested load times using DUMP.EXE:
Using MT32.mid it took 25s
Using your MT32_GM_Mode.syx it took 11s
So it's much faster! And the MT-32 sounded proper if I used DUMP.EXE with the SYX file instead of the MID, so that's what i'll use in my mt2gm.bat script.
Thank you again!
Doom sounds surprisingly good with this patch set 😀
