First post, by fsmith2003
- Member
As it seems a CT1330 is near impossible to find these days I was looking for a compatible that someone might recommend? Something with comparable quality and design (Dual OPL2).
You could keep an eye out for the original Media Vision Pro Audio Spectrum... but it is even more unobtanium than the CT1330.
http://www.amoretro.de/2012/03/mediavision-pr … -8-bit-isa.html
Yeah those do seem to be rather elusive as well. Thanks for the info though. I will keep my eye out for one.
Audician 32 Plus or ESS 1868 for CT1600 SBPro2 replacement.
CT1330 is unobtanium now, and useless on anything faster than a 486 if you did have one.
There are a handful of titles that take full advantage of dual OPL2 chips on the Pro 1 while having no compatibility with stereo OPL3. As with the PAS vs the PAS16, there is no equivalent available outside emulation.
