What is TDMA?
First post, by Tmp2k
This was in the manual for my Chaintech 6ATA2...
Integrated PCI Audio Subsystem
- AC'97 v2.1 CODEC onboard
- Full-duplex operation for simultaneous recording and playback
- Direct mixed audio streams to USB speakers
- Advanced wavetable Synthesizer using wavedata on the system memory
- Legacy DOS games compatible via TDMA
- Meets ACPI standard and PC98 WHQL audio requirements
Legacy DOS games compatible via TDMA? how does this work?
Reply 3 of 6, by aquishix
mrau wrote:
you need a proper driver and the games wont notice its a pci maggot infested architecture instead of isa
What's so bad about PCI? ISA had plenty of its own problems, wouldn't you say?
Reply 6 of 6, by Kamerat
Funny thing is that it probably runs in DDMA mode with the chipset of your motherboard.
mrau wrote:
this is not about whether pci is this or that, it just does not work the intended way without additional driver support;
The ESS PCI chips doesn't require any drivers, just need to be initialized by setting the right PCI registers. There is a TSR for IRQ emulation which is handy if the PCI IRQ of the card is not 5 or 7.
Tmp2k wrote:
Any idea where to find the DOS drivers for the audio chipset on this board?
http://vogonsdrivers.com/getfile.php?fileid=60
YouTube channel
