Mother of derp! I mixed up the original and control samples... ARRRGH! Fixed 😅
OK, first results are in!! 😁
There may be more results to follow as I do more recordings. For starters, though, we'll go with a recording of the card playing no sound.
Methodology:
- Audio directly recorded from the Line-Out jack of the CT2760, going into the Line-In jack on my onboard audio.
- I had originally fixed the floating amps on the card, then carefully removed the fixes afterward to reconstruct the 'before' configuration
- All output volume levels set to 50% via Windows Me's Volume Control
- Computer case was closed between recordings
- CD audio cable hooked up
- Only the Line-In, Microphone and PC Speaker outputs were muted within same volume control
- I used Audacity as I couldn't get MDFourier working on Linux for the life of me... forgive me, I tried
- I honestly don't know what dB level my equipment records at. Likely commodity -10dB, or whatever it's called, as I'm using just the line input.
My particular setup:
- Motherboard is a Tekram P5V30-B4, with Pentium FDIV 90MHz, 64MB RAM, 512K cache, 3dfx Banshee 16MB PCI, and 40GB Barracuda IV hard drive running on a Promise Ultra/66 card, running Windows Me
- Sound card is a Creative Sound Blaster AWE32 CT2760, first revision
- I have replaced some of the MC3403 op-amps with TL074 and TL084
- Some of the caps on the TEA2025 output were changed, but are likely not involved in this test anyway as I am using the Line Output
The control recordings:
These are provided to show how noisy my lame-ass equipment is (and to show what to logically subtract from the other graphs).
Log Spectrum:
Linear Spectrum:
Recording: (zipped because my version of Audacity refuses to export to flac for some ridiculous reason)
- Filename
- control.wav.zip
- File size
- 518.88 KiB
- Downloads
- 39 downloads
- File license
- Public domain
