First post, by EdmondDantes
- Member
I posted a more detailed account on my blog:
https://jispylicious.wordpress.com/2018/05/30 … ge-too-i-guess/
But the short version is, I tried to upgrade my comp, replacing an ISA Soundblaster 16 with a PCI Soundblaster 2 Audigy (not ZS), but whenever the Audigy was plugged in, no image would ever come up on my monitor.
Comp specs:
700mhz AMD (Thunderbird I think)
512mb pc133 ram
the mobo is an Epox-8KTA (either a plus or a 2, I forget which)
video: Voodoo 3 2000, PCI version
--NOTE: I did at one point replace this with a Geforce ti4200 AGP just to see if maybe the Audigy didn't like the Voodoo, same problem.
--I never did test the Aud with just the onboard video tho.
I can't remember but I think the power supply was at 500-700watts?
I took out any other optional cards when I was trying to get the Audigy to work just to prevent the possibility that they might be a problem.
If anyone has suggestions, throw them at me. Thanks in advance!
