First post, by appiah4
I found the below card for sale; it's a Magic S23A but unlike others I saw online it doesn't have the CS4237B chipset + CS9233 wavetable; instead it's a very sparse PCB with empty solder points for the wavetable etc. components and has only what I assume is a very integrated CX4236B chip on it. I can't seem to find any datasheets for the CX4236B online. Does this chip have an integrated CS9233 (ie. a GM wavetable) or is it just a CS4237B with integrated Crystal FM? Also, is this card's OPL3 terrible like the CS4235 or bearable like the CS4237?
Reply 1 of 8, by gdjacobs
The CS4236 is in the same vein as the CS4237 with an integrated SB Pro/WSS codec and controller. The onboard CrystalFM is the same improved version as the CS4237 and not the buggy one from the CS4235 chip.
I believe the only difference between the CS4236B and CS4237 is the inclusion of SRS 3D sound on the newer chip.
Reply 2 of 8, by appiah4
When you refer to CS4236 do you mean CX4236 because the card is equipped with the latter?
So no wavetable functionality on this card unlike other S23As?
Reply 3 of 8, by gdjacobs
I'm not sure why they are labeled differently, but regardless I'm referring to the Crystal Semi 4236B chip.
DSA0068017.pdf
38.22 KiB
75 downloads
Reply 4 of 8, by appiah4
DSA0068017.pdf
I see. I already have a cs4232 card do these chipsets have any fundamental differences for example in crystal fm implementation? Is this materially superior to CS4232?
Reply 5 of 8, by gdjacobs
CS4232 doesn't implement FM by itself. I'm aware of three options -- a companion chip Crystal made which includes a variant of Crystal FM as well as some 3D-ish processing, FM onboard a Crystal/Dream wavetable synth chip, and OPL3 implemented via a Yamaha chipset or illegal 100% clone. I'm not sure how your card implements it.
I haven't done any head to head comparisons, but I personally hate the version Crystal implemented on their FM/3D chip. I'm told that the CS4236 and newer use a better implementation.
Reply 6 of 8, by appiah4
Mine has the cs4289 fm/3d companion chip. Now I feel obliged to get the cx4226 if only to compare.
Stii unsure what the difference between CS and CX 4236 are though.
Reply 7 of 8, by gdjacobs
*shudder*
One letter?
Reply 8 of 8, by dr.zeissler
My D1026 has that same chip. Sbpro is very good, but has some compatibility issues with demoscene-stuff, the games were fine except DN2. When duke speaks "I'am back" the system freezes regardless ems/xms or any other config. I use the drivers for the magic23a. Phil has newer ones on his site: https://www.philscomputerlab.com/crystal-cx4235.html
I will test these today.
FM is quite good but not so good as my ess-solo1 (1938). Some percussion/snare sound are a bit off or to loud but a lot better then on phils video. Overall very good for an onboard solution.
Doc
