First post, by umcumc
Mr. authorized
Features of my computer:
Intel 486Dx2-66 processor
16x2 Edo Ram
420 Mb Hd
1.44 Floppy
5.25 Floppy
Umc Vesa Local Bus 1Mb Svga graphics card.
Umc control card
Sb Awe 64 Value sound card
200 Watt Power Supply
My problem is;
I have installed several dos games on the system while using Windows 3.1. Awe 64 midi music started playing incorrectly while playing normal. Instead of piano sound, gong sound or guitar sound instead of drum .. I did everything. I've erased all the drivers. I cleaned Config, Autoexec, win.ini and system.ini files. Finally I formatted the computer and installed a new windows 3.1 (retail). The first thing I did was install Awe 64 drivers. I ran the diagnose program under the Sb16 directory. The result is the same even under MS dos. All the voices are mixed. Midi music is not where there is no sound. I could not find a solution. Any ideas?
Result: Midi music plays with wrong voices. 🙁
Reply 1 of 1, by Tiido
Increase wait states / recovery time on 8bit ISA accesses in the BIOS or if that option doesn't exist then reduce ISA bus speed.
