First post, by GabrielKnight123
Hi all, I have a Pro Audio Spectrum 16 here:
http://s836.photobucket.com/user/sierragames/ … f1yhkr.jpg.html
The audio cable going from the DVD to the sound card are different, the sound card has a redish 5 pin plug but only 3 wires are used most likely Left/Ground/Right and I need to know which wires from the 5 pin plug are what so I can cut the other end off to solder on a standard plug to goto my DVD drive. In the picture the redish plug has pin 1 on the left, the leftmost and rightmost pins are not used.
Reply 1 of 2, by skitters
At ftp://ftp.mpoli.fi/unpacked/hardware/sound/pa … .zip/p16q&a.txt
it says:
The Internal CD-Audio Connector at J5 is a 5-pin header connector, 0.100"
space header, pin 1=ground, 2=right in, 3=ground, 4=left in, 5=ground.
Hopefully that will help.
