First post, by northdale
Hi.
In the gravis configuration I can set the number of active voices, and select 8bit instead of 16 bit.
Would this have any effect on games?
I tried doom but I could not hear any difference.
Edit: Since in the games you often select how many voices you want and if you want 8 or 16 bit sounds, I don't think it matters.
youtube.com/uncleawesome
