First post, by ChAoS Overlord
As I was inspired by Phil's Computer Lab, I'm going to build a dedicated MIDI-emulation computer that can act as an MT-32 (or other midi synth). https://www.youtube.com/watch?v=BQ759oY5EKg
I want to connect this emulator machine to my only retro rig (a windows 98/XP machine) using my SB Audigy. As I have the SB1394, I would require the separate bracket. But I don't find it anywhere. Can anyone point me in the right direction to solve this, or should I go to ebay to get a 2nd hand SB Audigy (2) with the bracket?
I do have the UM-ONE Mk2, which I'm going to use with the emulation computer. I would use a second one of them with the retro machine, but it's not compatible with Windows 98 (or DOS). This is why I'm looking for an Audigy, so I could get great compatibility in Windows and okay/good compatibility in DOS (mode).
Reply 1 of 13, by Kamerat
The MIDI port on the Audigy doesn't work under DOS so you'll need another card.
YouTube channel
Reply 5 of 13, by Kamerat
Then pick up an ESS ES1938/Solo-1 based card, should work fine under DOS on your motherboard.
YouTube channel
Reply 7 of 13, by Kamerat
Yes, no problem. Under DOS I would only initialize one card at the time, preferably the Solo-1.
YouTube channel
Reply 8 of 13, by ChAoS Overlord
I understand, but that way I'm missing out on the superior (?) soundblaster for effects? I would use the Solo-1 (that I ordered through Aliexpress) only for connection to my MIDI emulation computer.
Reply 9 of 13, by Kamerat
As for the chinese Solo-1's it might miss some of the resistors connecting the MIDI signals to the DB15 connector on the back of the card. 😖 If you got some soldering skills you could just bridge the solder pads. The Audigy emulates SB16, so it could be useful in some games, but the need for a TSR and EMM386 could break compatibility for others.
YouTube channel
Reply 12 of 13, by Srandista
You ordered this one?
Reply 13 of 13, by ChAoS Overlord
Srandista wrote:
You ordered this one? […]
I think your image isn't working. It's this one: https://www.benl.ebay.be/itm/192653699578?_tr … 8.N41.S1.R1.TR2
It's kinda funny, you and me take a similar stance to overpowered retro computing. I only chose to use a SATA SSD (still need to finish the build though)
