Sound Card Selection?
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby gryffinwings » 2018-9-11 @ 02:10
I'm wanting to buy a sound card, but I am not sure what I would get, my first thought is to get a Sound Blaster Audigy, as you can get them cheap on Ebay, but since I'm here now, I'd like some recommendations on what else I could get, the only other option I hear that is good is the Diamond Multimedia Monster Sound with the Aureal Vortex 2 chip. I like to play games and listen to music. The motherboard is the Asus A7V266-E with the C-Media CMI873 audio chip, which sounds ok, but I figure I could probably improve upon this. Also, I'm currently running Windows XP.
gryffinwings
Re: Sound Card Selection?
Postby cyclone3d » 2018-9-11 @ 02:56
Audigy 2 ZS or X-Fi (not audio express as it does not use the real X-Fi chip).
Some would say an Aureal for 3d sound though.
The Audigy 2 ZS or X-Fi card will have a higher SNR (better, cleaner sound) though so if you are using hi quality headphones or a good stereo setup you should be able to tell a difference.
Either is cheap enough so you could get both.
Don't worry about getting a Diamond branded Aureal based card. Any with the 8830 chipset will be fine.
Here is one from a Dell machine (Turtle Beach) that is currently $10.16 shipped
https://www.ebay.com/itm/Dell-Dimension-3000-PCI-Audio-Sound-Card-Board-0005931D/323424603351
User avatar
cyclone3d
Postby gryffinwings » 2018-9-11 @ 03:36
cyclone3d wrote:Audigy 2 ZS or X-Fi (not audio express as it does not use the real X-Fi chip).
This is very helpful, those Diamond cards are kind of expensive, what's the difference for between the dell card and the diamond card?
Any major differences between the x-fi and the audigy 2 zs? I noticed the x-fi had a cleaner lay out. Seems like either one is going to be good, which ever is cheapest.
I was thinking about adding a second card later too like an M-Audio Audiophile 2496, but I hear that it's mainly just for music, but I will have to have better speakers to take advantage of them.
gryffinwings
Postby cyclone3d » 2018-9-11 @ 03:50
The X-Fi is newer. It is going to have cleaner output and people like the surround for headphones a lot better.
The drivers are going to be better overall as well.
I've never personally compared the two.
I don't have one of the Diamond branded vortex 2 cards, but the Turtle Beach and the Diamond card should sound pretty much the same. Same chipset and the codec should be very similar.
I think the Diamond branded card is just more well known and a bit less common so it fetches a higher price.
The turtle Beach cards came in Dell machines so there are a ton of them out there. There are also a different versions with the same Dell model number. Just have to make sure you get the one, like I linked, with the Vortex 2 chipset.
User avatar
cyclone3d
Return to Sound
Who is online
Users browsing this forum: No registered users and 4 guests
