First post, by retro games 100
- l33t
Is the DAC on the Roland SCB-55 GM/GS daughterboard called the NEC 63200, and if so, is it like the one on the Roland SCB-7 DB, in as much as it's the same, ie it's 16-bit, 2 channel? Thanks a lot for any info.
