First post, by n-0rt
Recently got an Audigy 2 ZS sound card for the XP build I'm currently in the process of putting together... however, it arrived minus the bracket to screw it in place. While it doesn't stop the card from working, it bothers me having the card just sort of floppin' around held in place by the PCI slot only. I have had a bit of a look around for a generic bracket replacement, but the Audigy 2 ZS has the addition of a firewire port on the back, making it tricky to find something that'd fit. Does anyone know of a means I could more securely fix the card in place?
