First post, by PC386
I have aquired a Roland cm-32P,and from what i saw is not even midi game compatible.
Is it consider Junk or is there a mod way to make it work with Pc mt-32 compatible games?
Maybe burn CM-32L roms ?
What do you think ?
Thanks in advance
Reply 1 of 4, by keropi
Sadly it's not suitable for pc-gaming and you cannot make it into a mt-32 device because it's completely different hardware, it was made to accompany CM-32L and provide sampled sounds to use at channels 11~16 AFAIK.
CM32-L + CM-32P = CM-64 , I think some X68000 (or PC-98?) games can use the CM-64 but other than that nothing else that I know of...
Reply 2 of 4, by yawetaG
Even if you can't use it for games, don't throw it away, but sell it. Someone might be interested in it for music production purposes.
Reply 3 of 4, by SuperDeadite
Paired with a CM-32L you get a cheap CM-64. Fantastic for the X68000 computer line. The games Choujin and Gemini Wing can use the PCM expansion slot cards too
Modules: CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster
Reply 4 of 4, by PC386
Hi guys
Well the intention was to buy a cm-32l but the mistake was I thought the cm-32p had the same compatibility...
I Was thinking if the cm32L roms where put into the P version it would work but I think the P wouldn't have the linear aritmathics ic or so meting. .
Best regards
