Thanks a lot.
So the Pro has 8.5MB, when it has 2x 4MB SIMMs?
The regular has a maximum of 8MB? Never 8.5MB?
Please could you explain the CD-ROM audio connectors? Looking at your two photos, they seem to be about the same? Is one for ATAPI (is that also called IDE?), and what is C.L. - is that the proprietory Creative Labs connector?
Thank you!
Edit:
Wikipedia says -
In 2014 a RAM adapter for 72-pin SIMM was produced by retro-computer enthusiasts that made it possible to install 16 MB of RAM on the 'Pro' version without any modifications to the card.
Is this true for the Pro Version 1.0, as well as other versions too? Thanks.
Edit 2:
Apart from compatibility with the GUS Classic, what other sound compatibility standards does the GUS PnP support? Thanks.
