First post, by Ozzuneoj
- l33t
Is there any definitive way to find out which MIDI standard a game's soundtrack was primarily written for?
When using Mobygames to filter games by sound standards supported, I'm surprised by just how many games require at least a 286 or 386 but support the MT32 AND General MIDI (or Sound Canvas). I always pictured the Sound Canvas as being used a bit later, but there's actually a ton of overlap.
Is it safe to say that most games that support the Sound Canvas probably were designed with that device in mind, since it is the newest? I know some games have different MIDI tracks depending on the sound driver selected, but is this the norm? It seems logical that even when you have separate tracks for certain devices, a composition would still take better advantage of one or the other, depending on the composer's experience or preference... but how can you tell without just listening to every track on every device? I'm not going to obsess over it because I love the sound of both devices, but it'd be nice to know if there is a list compiled somewhere to say which device is preferred for which game. I'm sure there are even some composers that had a love for FM music so their FM tracks sound exceptionally good, even if the MT32 or GM tracks sound more "realistic".
Either a list or just observations would be helpful. If observations could be posted so that they clearly indicate the game and sound device being mentioned, it would make it more easily searchable.
For some background as to why I'm looking into this:
I'm going to be trying to complete my first 386 build and I'm trying to sort out what the specs should be. I know its nearly impossible to have a one size fits all system that covers more than a couple years, but I'm trying to set this system up so that it covers basically all of the earliest VGA games up through the first games that really need a good 486 to run well. The systems specs will most likely consist of:
AM386SX 33Mhz + 64KB 20ns Cache
4MB 70ns RAM
SIIG Enhanced IDE multi-IO card
Diamond Speedstar VGA Tseng ET4000AX ISA
SB2.0 CT1350B + CMS upgrade
Midiman MM401 Inteligent MPU401 interface connected to Roland MT-32 and SC55
I might experiment with a MediaVision Thunderboard, Soundblaster Pro 2.0 or some other older soundcard I have too...
This system will offer no less than four sound standards, so I'll be able to experiment quite a bit. I'm curious about the "preferred" device for each game though, to see if I can hear the difference. 😀
