Blown cap on my Roland SC-88 (pictures inside)
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby Woolie Wool » 2019-1-10 @ 04:48
A couple weeks ago, during a Doom session, I started hearing a strange crackling from my Roland SC-88. Initially thinking it to be a problem with my DAC or the Toslink cable I was using, I fiddled with the cables of my audio setup several times before resuming. Then, in the middle of a fight, I heard incredibly loud digital crashing and grinding noises...and the music stopped. Ever since then the DAC has produced nothing but static crackling with the occasional burst of distorted music before going back to crackling again. I initially thought the analog board was at fault, disassembled the machine, and checked all the capacitors. They were perfect, and there were no signs of damage to the board. Furthermore, the SC-88 works fine as a preamp for an audio source and the diagnostic routines indicate errors in...the MIDI engine? Uh-oh.
So then I started googling people who had problems with their SC-88, and found this story. This guy's problem was on the digital board. It turns out a capacitor labeled C38 had blown, so I brought mine out to my workplace where the lights were much brighter at home, and conducted some exploratory surgery.
It's C38. The very same cap as that guy's problem. It blew and spewed a bit of cap juice. The capacitor C39 and the chip IC22 may have been contaminated by electrolyte and damaged, but it's hard for me to tell.
Pictures (click to embiggen):
Overview and analog board.
Digital board. Wait, what's that? Let's take a closer look.
C38 and electrolyte bukkake.
So now that I know what the problem is, what to do? I'm unfortunately not particularly great with my hands and have no soldering expertise. I do, however, have the machine itself, the service manual, records of all the diagnostics I ran, and someone else's example of how to fix this problem. Is there anyone here who might be able to point me towards someone who'd be willing to take on repairing this thing? I'd hate to throw it in the garbage and get a new one, even though it might cost me less in the end.
User avatar
Woolie Wool
Re: Blown cap on my Roland SC-88 (pictures inside)
Postby cyclone3d » 2019-1-10 @ 05:35
Where are you located?
That is literally like a 5-10 minute fix.
User avatar
cyclone3d
Postby Woolie Wool » 2019-1-10 @ 14:06
Memphis, TN.
User avatar
Woolie Wool
Postby CrossBow777 » 2019-1-10 @ 19:12
Woolie Wool wrote:Memphis, TN.
When you do get this fixed, I'd replace all of those surface mounts with either brand new surface mounts or if space allows, radial electrolytics like what is used on the analog board.
User avatar
CrossBow777
Postby cyclone3d » 2019-1-10 @ 19:20
Ok, so not that far away from me. In any case, it would probably be just as cheap and a lot quicker to have a local electronics repair shop replace the cap(s) for you.
Here are a couple that get good reviews on Yelp!
https://www.yelp.com/biz/digitech-electronics-repair-memphis-2
https://www.yelp.com/biz/electronics-repair-center-memphis-2
I would call them up and tell them what you need and ask a range of how much it would cost.
User avatar
cyclone3d
Postby Woolie Wool » 2019-1-12 @ 00:22
I called up the former of those two shops and I'll be taking the SC-88 and service manual in tomorrow. Thanks!
User avatar
Woolie Wool
Postby pentiumspeed » 2019-1-12 @ 00:59
The guy who replaced that C38 capacitor (due to new shiny solder with brown hard solder flux around it) forgot to clean up the former old capacitor's corrosive goo and repair traces and vias around C38. You'll have corroded traces and vias as I can see the vias and copper square that marks one corner of chip is corroded away. That need to be redone. And very smelly when soldering those. Scent of rotten fish.
I have done this all the time on PIP boards for certain brand TV and other brands that used corrosive capacitors I had to repair any that were eaten away that a decade ago when I was a TV tech repair person. My current job fixing cellphones but no corrosive stuff except for any that took a dive can be treated and repair if any found, yet there is difference is everything is done with microscope. :)
Cheers, pentiumspeed
pentiumspeed
Postby Woolie Wool » 2019-1-14 @ 15:10
The SC-88 is in the shop now. There was a mixing console and several other pieces of complicated audio equipment in the store's atrium, so if anyone can fix this thing, Digitech probably can.
User avatar
Woolie Wool
Return to Sound
Who is online
Users browsing this forum: No registered users and 5 guests
