Sound Blaster Installation Detects Windows 95
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby Lo-ResBros » 2019-1-11 @ 23:31
I’m trying to install Sound Blaster 16 drivers in DOS after installing Windows 98se but the installation says it detects Windows 95 and aborts the install. I’m doing this while re-booted in pure dos btw.
I read a while ago something about this and you have to rename a file or directory? I can’t remember or find the post anymore.
*Sorted it out. Watched a Philscomputerlab video for msdos mode installation*
MS-DOS: Pentium MMX 233MHz -Tyan TitanVX S1470 Motherboard - 128MB Ram -ATI Rage 128 PRO 32MB Video Card
XP: Pentium Core 2 Duo 3.0GHz -EVGA 750i FTW Motherboard - 4GB Corsair Dominator 1066MHz Ram -XFX GeForce 9800 GT 512MB Video Card
Lo-ResBros
Re: Sound Blaster Installation Detects Windows 95
Postby GigAHerZ » 2019-1-11 @ 23:38
I don't know exactly, what instructions did you read, but you could rename "Windows" folder before installing DOS drivers in the DOS.
DOS drivers are really easy to install manually: Just copy some files over and change config.sys/autoexec.bat a bit and you're done. ;)
User avatar
GigAHerZ
Postby Jo22 » 2019-1-11 @ 23:40
That is -or was- normal, I believe. The Creative drivers detect DOS 7 and refuse to install because they think it's a Windows 95 system.
Back in time, there used to be several threads about this according to my memories.
However, I'm no Win 9xGuru, so I don't know what the workaround for this used to be.
With tools like DOSVER you can fake another version number, maybe this helps.
Not sure, though. DOS 7 also had additional DOS APIs (or ABIs) that could be used for detection of DOS 7+.
User avatar
Jo22
Postby Lo-ResBros » 2019-1-12 @ 00:08
GigAHerZ wrote:I don't know exactly, what instructions did you read, but you could rename "Windows" folder before installing DOS drivers in the DOS.
You're right I managed to manually install the SB16 with a driver I downloaded off here that already has the files installed and just edited the autoexec and config, however I plan on using a AWE64 soon and might be a little harder, would be nice to use the normal installer if possible.
Lo-ResBros
Return to Sound
Who is online
Users browsing this forum: Stretch and 2 guests
