Tube Time: Announcing The Snark Barker, a 100% Compatible SB 1.0 Replica!
Discussion about old sound cards, MIDI devices and sound related accessories.
Re: Tube Time: Announcing The Snark Barker, a 100% Compatible SB 1.0 Replica!
Postby root42 » 2019-3-26 @ 16:37
You also need the Yamaha DAC. Or else there is no FM sound...
Soldering, retro game reviews and more on YouTube and Bonus videos
Me playing games on my 286 and on my Sega MD2 on Twitch
80386DX@25 MHz, 8 MiB RAM, Tseng ET4000 1 MiB, schlae AdLib, PC MIDI Card + SC55MkII, XT CF Lite, OSSC 1.6
User avatar
root42
Postby Cyrix200+ » 2019-3-26 @ 18:39
root42 wrote:You also need the Yamaha DAC. Or else there is no FM sound...
The DAC came from another seller, and it arrived two weeks ago.
User avatar
Cyrix200+
Postby Cyrix200+ » 2019-3-27 @ 20:59
Some volume knobs arrived today, my brother printed them. They're black, with glitter because he has a sense of humour :P (and I think thats what he had available at the moment).
It wasn't a very high-res printer, so there are two knobs with a more ridged design (giggity).
User avatar
Cyrix200+
Postby root42 » 2019-3-27 @ 21:17
They look good! I think the extra ridges are a good idea. I have the standard STL, and it is quite slippery.
User avatar
root42
Postby Cyrix200+ » 2019-3-28 @ 09:01
root42 wrote:They look good! I think the extra ridges are a good idea. I have the standard STL, and it is quite slippery.
I'm looking for a screw now. There are large boxes on eBay/Aliexpress but that takes forever to get here and I would have to buy 1000 screws to get one I need :) local hardware stores don't stock it.
Where did you get yours?
User avatar
Cyrix200+
Postby root42 » 2019-3-28 @ 10:09
User avatar
root42
Postby Cyrix200+ » 2019-3-28 @ 11:09
root42 wrote:https://www.microscrews-shop.nl/
https://www.microscrews-shop.nl/a-28468 ... x-6-10-st/
Should be this one then :) Funny, I found that site a few days ago, but somehow missed that they have these
User avatar
Cyrix200+
Postby root42 » 2019-3-28 @ 14:07
Yes that one will fit. I took one with a conical head, but the flat head should be fine.
Concerning the bracket: We really need someone to make some professionally, I think... I tried to mod a Keystone bracket, but the DB15 and the volume wheel hole are really a pain...
Maybe for the meantime I will make an STL file for printing, as a stopgap measure.
User avatar
root42
Postby Cyrix200+ » 2019-3-28 @ 14:24
root42 wrote:Yes that one will fit. I took one with a conical head, but the flat head should be fine.
These guys, maybe. Although the price will probably be astronomical. http://www.bracket.com/products/brackets/
EDIT: It's problably way smarter to find a local company that can (laser)cut metal.
User avatar
Cyrix200+
Postby root42 » 2019-3-28 @ 15:16
Almost the right one:
http://www.bracket.com/downloads/bracke ... 90001B.pdf
But yeah, there are a couple of companies that could make the exact bracket. Cost will probably in the order of 10 EUR per bracket for a small batch (you probably won't find any company doing batches less than 100).
User avatar
root42
Postby Cyrix200+ » 2019-3-28 @ 15:18
Huh, did not find that one, I did not do the search for 3 rond holes. It's dated 1993, So it's probably another ISA sound card. Really cool they have it all available online.
User avatar
Cyrix200+
Postby Cyrix200+ » 2019-3-28 @ 19:57
NE558, YM3812 and SAA1099 arrived today :) Little screws should arrive tomorrow, and then it's just the bracket. Not tested it yet!
User avatar
Cyrix200+
Postby Benedikt » 2019-3-28 @ 22:15
On a similar note: Would it be possible to mod this one or to mount the potentiometer on a piece of perfboard behind the third round hole?
It looks like a bracket for a PCI Sound Blaster card.
Could someone take a look at the datasheet and compare the hole placements?
Benedikt
Postby Dubinius » 2019-3-31 @ 19:19
Wow,
i wasn't visiting Vogons for this Year - Shame on me - and an Friend told me for that Snark Barker here, ..
What an AWESOME Project, ...
Damn :D I had a lot of empty and unsoldered "other" Projects like the Micro8088 from Sergey and now that Sound Card Clone, ...
My Stainless Steel Iron with Lead Solder can't wait for that, ... but i have to wait a little :cool:
Greetings
User avatar
Dubinius
Postby root42 » 2019-4-01 @ 14:14
Dubinius wrote:Damn :D I had a lot of empty and unsoldered "other" Projects like the Micro8088 from Sergey and now that Sound Card Clone, ...
Where did you get the Micro8088 PCB? I do have a couple of V20s and Faraday ICs, but wouldn't want to order 10 PCBs again.
User avatar
root42
Postby AnacreonZA » 2019-4-15 @ 09:44
Got my card working after a fashion this weekend. I discovered that the DB-15 sockets I had were male rather than female so I desoldered the second DB-15 from a dedicated game port card I had. I also socketed that cards NE558 so I could use it. I managed to use an audio socket from a scrapped PC by cutting off two of the legs as well. I still do not have the opamp for the OPL chip but I was super happy when Wolf3d picked up the card and blasted that door opening sample through my speakers when I started playing.
CMS sound does not go though the same opamp as the OPL - and works properly. In fact a lot less noisy than the MUS-1099 card I built recently.
My CH Flightstick works fine with the joystick port - tested it a bit in Descent and TIE Fighter.
Most games with auto-detect routines seem to pick the card up. Also played a few early demos like Crystal Dream and they sound decent as well. Very chuffed with this card.
AnacreonZA
Previous
Return to Sound
Who is online
Users browsing this forum: No registered users and 3 guests
