YMF744 Gameport
Discussion about old sound cards, MIDI devices and sound related accessories.
YMF744 Gameport
Postby Ri0tg3ar » 2019-2-09 @ 13:54
So I picked up an aopen aw744l II PCI sound card for my dos build sound works fine however I cannot get the gameport to work with joysticks in windows or dos.The gameport is detected in windows but i cant seem to get it to see my joysticks,I have 5 and they all work on a usb to gameport i use on my windows 10 pc. Am I missing something? Does it just work for midi?
Ri0tg3ar
Re: YMF744 Gameport
Postby j^aws » 2019-2-09 @ 19:16
Ri0tg3ar wrote:So I picked up an aopen aw744l II PCI sound card for my dos build sound works fine however I cannot get the gameport to work with joysticks in windows or dos.The gameport is detected in windows but i cant seem to get it to see my joysticks,I have 5 and they all work on a usb to gameport i use on my windows 10 pc. Am I missing something? Does it just work for midi?
I've never tested it, but its manual definitely refers to the joystick port, so not just for MIDI.
j^aws
Re: YMF744 Gameport
Postby cyclone3d » 2019-2-11 @ 04:11
Is it the only card with a gameport installed in your system?
It should definitely work with joysticks.
What are the rest of the specs for that system?
User avatar
cyclone3d
Re: YMF744 Gameport
Postby ibmapc » 2019-2-12 @ 02:05
Have you installed all of the drivers for the card? When the windows driver is installed, you will need to activate the game port. You may need to remove any other game port driver that may have been previously installed before installing the YMF744 driver. Also, there is a separate utility to set it up for DOS. I think it's called Real_Dos, or something like it.
User avatar
ibmapc
Re: YMF744 Gameport
Postby Ri0tg3ar » 2019-2-12 @ 02:52
Yes i have all of the drivers installed like i said sound works fine both in windows and dos I will try enabling the gameport in windows and see if thats what it was. A seperate utility for the gameport? is it different than the dsdma/setupds?
Ri0tg3ar
Return to Sound
Who is online
Users browsing this forum: Zero_sugar and 2 guests
