Augidy 2 ZS and Gaming Sound help
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby kmccmk9 » 2019-2-10 @ 04:49
Hello,
So I finally got my Audigy 2 ZS installed under Windows 98 SE. All of the system sounds come through just fine, CD Audio works fine as well. However, when trying to launch most games I do not get any audio. Most games don't produce an error just silence. However, any of the Humongous Entertainment games do produce this interesting error that prevents the game from running: "during the dma buffer size search the sound card wouldn't prepare our sound headers". I honestly have no idea what to do with that. I've tried googling and searching the forums but I can't find anything. I tried disabling hardware acceleration on my sound card and I've also tried enabling DMA on my CD-Drive. I'm at a loss...any help would be greatly appreciated.
kmccmk9
Re: Augidy 2 ZS and Gaming Sound help
Postby dr_st » 2019-2-10 @ 06:03
Welcome to the forum. :)
Are the games you are running (that have no sound) DOS games?
User avatar
dr_st
Postby kmccmk9 » 2019-2-10 @ 06:29
Hi, thank you. Long time lurker of information but now I have a "working" 98 rig, figured I'd join in the conversation. The games are not DOS games. Windows 95 and up...I also tried running them in DOS mode, but it errors and says it isn't compatible with DOS mode.
kmccmk9
Postby kmccmk9 » 2019-2-11 @ 22:29
Also, if it helps I'm using a Asusp 5pe-vm motherboard. Now, interestingly, I have a hazard icon for the sound/multimedia device on the motherboard. Maybe if I install the motherboard sound drivers?
kmccmk9
Postby dr_st » 2019-2-12 @ 07:07
Normally, if more than one sound device is available (with installed drivers), then Windows selects some default option, and you can change it in the control menu. All applications will default to that sound device, unless they have their own configuration utility to control it. So it's very strange that all system sounds work, and all game sounds don't work.
Moreover, if you have a device but have not installed drivers for it, then it should simply be unusable to Windows, and should not cause glitches that you are experiencing; however, just in case:
1) Check the sound options in the control panel - verify that all the digital out, midi out, etc. is set correctly to the Audigy
2) Run DXDIAG and check that everything is OK there in the sound tab
User avatar
dr_st
Postby kmccmk9 » 2019-2-12 @ 07:20
1) Everything is set to use the Emu10Kx Mixer [E400] which I'm assuming is the Audigy card.
2)
DirectSound [Emu10Kx Wave Out [E400]]
Device ID: PCI\VEN_1102DEV_0004SUBSYS_20021102RE\
Manufacturer ID: 2
Product ID: 104
Type: VXD
Default Device: Yes
CTAUD9X.VXD
4.12.0001.0381
9/23/03
ctaud9x.vxd
Creative Technology, Ltd.
DirectX is set to full acceleration
No problems found
However, DIrectSound test failed at Step 10 (Secondary buffer): HRESULT = 0x8007000e (Out of memory)
kmccmk9
Postby kmccmk9 » 2019-2-17 @ 03:36
Interesting update, I tried uninstalling the hardware and software for my Audigy 2 ZS and reinstall using the CD available on vogonsdrivers. BIG MISTAKE. Nothing at all worked haha. So I removed the hardware and software and tried installing the drivers for my motherboard built-in sound. Similar to the other result I can hear the Windows startup chime (although it sounds terrible) and I can hear some sounds from some games (although terrible). Ironically Humongous Entertainment games still throw the same error. I ran DXDIAG sound test again and noticed it failed at Step 17 (out of memory). something very odd is happening and I have no clue what.
kmccmk9
Return to Sound
Who is online
Users browsing this forum: easy_john and 3 guests
