The Unofficial OPL2LPT and OPL3LPT demopack (for convienient testing of Adpatch)
Discussion about old sound cards, MIDI devices and sound related accessories.
Re: The Unofficial OPL2LPT and OPL3LPT demopack (for convienient testing of Adpatch)
Postby Artigkar » 2019-3-27 @ 16:46
pdw wrote:I found a copy of the Sim City 2000 demo here: https://archive.org/details/Simcity2000Demo, but there doesn't seem to be any sound in that version. At least I can't find a way to enable it. For the full release, the file is sound\a32adlib.dll IIRC. I'll also take a look at the other games.
That would explain why I could not get adpatch working with the demo!
It seems there is not even pc speaker sound in the demo version. I guess its some sort of extreme space/cost saving measure from the game developers.
While there are some notable games that seem to be missing from adpatch compatability, I think the list of games supported is quite impressive as is.
Certainly without your work on adpatch there would be no adlib sound at all in some of these games with OPL2LPT and OPL3LPT cards.
You get two thumbs up from me!
Are you thinking of updating the list of adpatch tested games on the github wiki page? If so, you should note that while adpatch seems to be working with Shadow Warrior shareware demo it will not work with the full version of that game. Shadow Warrior dropped adlib (and general midi) music in the retail release in favor of CD audio tracks. I thought this might be important because the demo can give a false impression if a person is not familiar with the game.
User avatar
Artigkar
Postby Artigkar » 2019-4-05 @ 05:46
ruthan wrote:We need big pack games as possible for testing of this device, if there are 2 different ways what has to be done to execute them. We can 2 sepate directories for each type of games and some text file info why it is divided, or some clever execution *.bat if TSR is unloadable etc..
We are now 1 step closer to something resembling this with the latest version of the demopack.
ruthan wrote: Could someone pleas test Dungeon Master I and Golden Axe I?
I don't have Golden Axe for dos so I dunoo about how that game works with OPL2LPT.
Dungeon Master 1 should work with Adlipt in theory, I am having some issues with the game on my 486 unfortunately.
It freezes on the Dungeon Master title screen for me, even with PC Speaker sound. At least I get the FTL games logo "WOOOOSH!" sound playing.
This is quite puzzling since I did manage to get the game working properly on that old laptop last year.
HMMM, gonna have to check it out more later. I think there is a way to force Adlib sound without going through the launcher sound card selection.
User avatar
Artigkar
Postby ruthan » 2019-4-05 @ 12:52
Dungeon master 1 - i could be problem that some sound card driver is loaded, even if is not used and i had some problem with such freezing on some systems related to mouse.. when i used keyboard only it worked.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough HW.
User avatar
ruthan
Location: Schwarz Wald-from France to Ukraine, from Denmark to Austria. Celts+German+Slavs melting pot.
Postby Artigkar » 2019-4-05 @ 18:46
That could be an issue, I have been changing and switching out some drivers on my 486 over the last year to get the smallest possible memory footprint.
Btw, when I put together the latest version of the demopack I came across a couple oddities.
The first is related to Lemmings 2. The demo version works with adpatch, you patch the ADLIB.ADV file in the game directory.
But with the full version, or atleast my copy of the full version, the Adlib driver is in a "MUSIC" folder inside the game directory.
The file is ADLIB.bin and Adpatch does not work with that one unfortunately. This will be an issue for 286 owners wanting to play full version of Lemmings 2 with OPL2LPT.
The other and maybe more interesting oddity is that the Pinball Dreams demo has no Amiga mod tracker music unlike the full version.
Instead it has a rather rough OPL2 FM conversion of the music playing with Adlib and Soundblaster.
Here is a quick video I recorded with Dosbox and shadowplay demonstrating the FM music:
https://www.youtube.com/watch?v=8Acbc2gM6rY
User avatar
Artigkar
Postby Artigkar » 2019-4-07 @ 19:05
ruthan wrote:Dungeon master 1 - i could be problem that some sound card driver is loaded, even if is not used and i had some problem with such freezing on some systems related to mouse.. when i used keyboard only it worked.
Turns out it was a much simpler and more embarrassing reason for Dungeon Master freezing on my 486 machine.
I forgot that copying folders in Dos does not automatically copy over subdirectories. The data subdirectory was not copied over :dead:
Good news is that Dungeon Master does indeed work with the Adlipt driver.
Anyway, I found out another thing. Running Adlipt while also running a adpatched game does not seem to cause a problem.
At least not with the two games I tested which was Whacky Wheels and Jill of the jungle.
User avatar
Artigkar
Postby ruthan » 2019-4-08 @ 22:31
Fine, if Dungeon Master working and much closer order adapter..
User avatar
ruthan
Postby pdw » 2019-4-29 @ 21:50
I've released a new version of ADPATCH. It's only lightly tested, but I didn't want to delay it longer...
What's new:
- A lot of LucasArts can be patched now. Should be nice for 286 owners. (386 owners can just use the TSR.)
- Another version of the Miles audio engine, which uses the file "ADLIB.MDI". (These games also work with the TSR though)
- Blood. This one does require patching.
For people who are asking about compatibility: if you check the system requirements of the game, and it supports 286 CPU & Adlib sound, then they're going to work without doubt with the TSR. If it requires a 386 CPU, there's a good chance it will work but it's impossible to say for certain without testing. (Also beware that in the late DOS era, in 1994/1995, many developers started dropping Adlib support.)
(Incidentally, I just discovered that Warcraft 1 & 2 work fine with the TSR. I hadn't bothered testing those before, they felt too new for Adlib...)
pdw
Postby digger » 2019-4-29 @ 22:30
Nice work, pdw! :)
Wouldn't the ability to patch more games (as an alternative to emulation) still be beneficial to slower 386(sx) systems as well? Or would the emulation overhead be negligible even on such systems?
User avatar
digger
Postby ruthan » 2019-4-29 @ 22:51
Warcrafts wow.. => it make sense to test much more games, if someone has this device and time.
User avatar
ruthan
Postby pdw » 2019-4-30 @ 06:39
digger wrote:Wouldn't the ability to patch more games (as an alternative to emulation) still be beneficial to slower 386(sx) systems as well? Or would the emulation overhead be negligible even on such systems?
I think performance is fine even on a 386SX. I don't have such a machine myself to test, but I haven't received any complaints.
pdw
Postby dr.zeissler » 2019-4-30 @ 07:38
Can we make an overview on which hardware you are using the opt-lpt device.
this would be interesting!
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): 3dfx V3-3000
dr.zeissler
Postby Artigkar » 2019-5-01 @ 05:54
dr.zeissler wrote:Can we make an overview on which hardware you are using the opt-lpt device.
I would be very interested in this aswell!
Personally I don't have a wide enough range of old school computers.
The 486 laptop I use works really well despite being from 1993! Compaq, 25 Mhz CPU and 4 MB of ram.
It struggles playing Doom at a playable framerate, but plays older games fine.
Besides my 486 laptop I have an AMD Athlon machine with a clockspeed of 1.1 Ghz that may or may not be functional.
It is the only other pc I have with a parallell port, but its not been used since the mid 2000s unfortunately.
NICE! I have added those two games and a few others to an updated version of the demopack.
User avatar
Artigkar
Postby dr.zeissler » 2019-5-01 @ 06:42
The real interest for me is, what is the better one.
An old style pc 386/486/pentium that can not have a dedicated sondcard (e.g. a laptop) or
a very late computer that do not have isa or pci cards usable but still can use an LPT.
dr.zeissler
Postby Artigkar » 2019-5-07 @ 20:48
pdw wrote:For people who are asking about compatibility: if you check the system requirements of the game, and it supports 286 CPU & Adlib sound, then they're going to work without doubt with the TSR. If it requires a 386 CPU, there's a good chance it will work but it's impossible to say for certain without testing. (Also beware that in the late DOS era, in 1994/1995, many developers started dropping Adlib support.)
Well, I tested the 1.0 shareware release of Tyrian on this sunday and it doesn't seem to be working with either Adlipt or Adpatch. I only get silence in both the setup music jukebox and ingame. Its a shame, it has one of the best Adlib OPL soundtracks out there of any Dos game. Maybe one of the later releases works?
EDIT: later releases of the game
User avatar
Artigkar
Postby Artigkar » 2019-5-14 @ 01:49
Well, I finally got my hands on the Dos version of Golden Axe and tried it with my OPL3LPT and the Adlipt driver.
It works well for the music, but sound effects are only PC Speaker (interestingly enough they are digitized sounds).
Was there Sound Blaster support for the SFX for this game?
User avatar
Artigkar
Postby ruthan » 2019-5-14 @ 05:20
I thing that game has only pc speaker sfx, but in case ehere im not sure im sinply testing it with Dosbox, where i can enable, disable pc speaker.. some andvanced builds have it in menu.
User avatar
ruthan
Previous
Return to Sound
Who is online
Users browsing this forum: No registered users and 3 guests
