Gameports and joysticks
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby foil_fresh » 2019-4-15 @ 04:23
Sure it's not a sound topic but it's a sound card topic... kinda.
Anyway!
I have bought 2 old joysticks, one is the Sidewinder Precsision Pro and also a Logitech wingman light. Both of these joysticks have drivers in windows 98 and they are options to select from the hardware when I choose to add a joystick device.
The problem is that I can't get either of them to work. I have tried on both my Win98se machines, one is a Soltek nforce board which has gameport built in (with the nforce audio onboard), it also has a SB live so there are 2 gameports on this machine. Both ports don't detect either joystick. I have also tried on my other P3 550/asus p2b with an sb live also (different card same model).
I plug them in, add the device, refresh... I reboot... no luck.
I have used the nforce chipset installer for the soltek board along with some w9x driver package from vogons (i think) and on the other P3 i have installed sb live drivers from the ISO on philscomputerlab website.
Would there be some caveat i'm missing with some sort of compatibility issue, or driver problem from the packages? I mean these joysticks are probably over 20 years old. I can't be sure if they work or not as I have no way to test these other than what I'm doing.
I also have a 3rd SB live card i -could- test as well as a hercules fortissimo card that i'm sure has a gameport as well. Any hints/tips before I try any more sound cards?
Cheers!
foil_fresh
Re: Gameports and joysticks
Postby cyclone3d » 2019-4-15 @ 04:58
You need to find a known working gamepad or joystick and make sure the gameports on your cards are working.
You really shoudn't even have to reboot when adding a joystick or gamepad.
My bet is either a driver issue or both of the controllers are bad.
Microsoft Sidewinder Precision Pro driver:
http://vogonsdrivers.com/getfile.php?fileid=568&menustate=0
Logitech Wingman light driver - this should be the latest:
http://vogonsdrivers.com/getfile.php?fileid=1034&menustate=0
or
http://vogonsdrivers.com/getfile.php?fileid=483&menustate=0
User avatar
cyclone3d
Postby foil_fresh » 2019-4-15 @ 05:02
Yeah I specifically bought the wingman to be the "test" device as it was sold as working but who knows.
I'll try those drivers like you mention. Thanks!
foil_fresh
Return to Sound
Who is online
Users browsing this forum: No registered users and 6 guests
