First post, by i2lgames
Hello, after years of use my sb16 ct2230 started giving me a "Wrong Base I/O Address or Audio Card is not detected at 220H" error. I tried everything i could regarding the software side of things. I tried using different motherboards but no luck. Do you have any suggestions on the hardware side?
Thank you.
