First post, by Rolandradio
Is there a way to play Indianapolis 500 the simulation (1989) over OPL2LPT ?
Command: indy /a (activate Adlib)
wrote:Is there a way to play Indianapolis 500 the simulation (1989) over OPL2LPT ?
I also have the same question. Need some answers.
Thanks in advance,
Regards
V
Maybe I ask Serdashop, you never now.
Technically is everything possible 😎
You can just use the TSR (ADLIPT.EXE).
(Or do you want to run the game on a 8086/80286?)
It works!
Config.sys jemm386
autoexec.bat Jload jadlipt.dll lpt1
OS: Freedos
Adlipt.exe is not required in this situation
