First post, by rishooty
Lately, I've been interested in just playing everything on my modern machine in the best way possible. For the most part, I use high-quality APTx-LL Bluetooth headphones with its accompanying adapter and it works fine. But I'm curious about the number of USB options I have for when I need to have it wired.
It seems nearly every USB X-Fi supports EAX, CMSS, and to some extent midi. However, in all my google searching, I can't find for the life of me which are actually hardware implementations. I can't even find their chipsets. For example, the SB1095, SB1290, SB-XFI-GPR2, and 70SB124000001.
On the other hand, I'm very interested in the Buran X3M, especially since the release of the unofficial roland soundbank: Unofficial Soundbanks for Dreamblaster X2 / X3M / X16.
My questions are:
1. Is a dedicated EAX device worth it w/ Windows 10, or can nearly every game be worked around with dsoal, indirectsound, or alchemy restriction remover?
2. Is the sound quality difference big enough between hardware and software midi for an X3M or even an SC55 to be worth it? Normally, I've just used EmperorGrieferus's update to Patch93's SC-55 Soundfont + CoolSoftMidiSynth. I remember midi sounding incredible on my Aureal Vortex 2 from my first retro build a few years back, but I'm not sure if its placebo effect from it being louder or something.
Reply 1 of 18, by Stiletto
Off-topic: what do you prefer for this?
do the Fandango!" - Queen
Stiletto
Reply 2 of 18, by cyclone3d
Soooo.. after doing some digging, it looks like maybe only the original Sound Blaster X-Fi Surround 5.1 USB (SB1090) is hardware accelerated.
http://ixbtlabs.com/articles3/multimedia/crea … ound-51-p2.html
The SB1095 is the "Pro" version of which I can not find any real info on the chipset. It is interesting that the earlier release of this carried the THX moniker while the later release carries the SBX moniker. Something to do with licensing.
So.. this version reportedly doesn't have hardware acceleration though the Recon 3d USB does:
https://pixelsandwidgets.com/2014/04/usb-soun … s-x-fi-5-1-pro/
The Creative X-FI HD USB (70SB124000001 or SB1240) uses the CA0189 whicch doesn't list anything about being hardware accelerated though it does use a RISC processor so maybe it is.
https://www.hardocp.com/article/2011/09/20/cr … d_card_review/2
https://www.creative.com/oem/products/chips/ca0189.asp
The X-Fi Go! (SB1100) may be hardware accelerated according to this: https://www.amazon.com/Creative-Labs-Blaster- … m/dp/B0017QQQAE
The X-Fi Go! Pro (SB1290) is apparently glitched and also has lower output quality and worse software than the non-Pro version)
https://www.head-fi.org/threads/sound-blaster … 8/#post-8788665
For me, I like Alchemy to restore EAX to older games. The X-Fi PCI and PCI-E cards (CA20K1 and CA20K2 based) sound great. Supposedly the newer cards that don't use those chips don't sound as good but I haven't personally compared them.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 18, by Logistics
Isn't the Extigy what you're looking for? It even has the MIDI connectors in addition to EAX and CMSS. IIRC, the only thing that is not legit is the Dolby, which is emulated.
Reply 4 of 18, by rishooty
The extigy doesn't seem to have drivers for Windows 10. I also noticed it has performance issues from being an early USB product.
As for my regular audio, I use the avantree leaf + avantree audition pro. Great sound and battery life, next to no lag. Best you can get short of sony's LDAC compatible sets, which only works on Android at the moment. Just of course know it will never be as good as wired, but it comes close and it's very convenient.
Thanks so much for the digging, it's good to know the ones I was looking at are probably accelerated. Now if I remember correctly, not even the card xfis have real midi/wavetable hardware right?
Reply 5 of 18, by BloodyCactus
pretty much any usb thing these days is going to be class compliant with no drivers.
myself I run a schiit bifrost (its an upgraded uber bifrost) as usb or as optical depending what I'm messing with.
https://www.schiit.com/products/bifrost
(mine is an original that has its insides upgraded twice). currently it has the gen5 usb and the AKM4490 dac in it.
Reply 6 of 18, by appiah4
Just get the X3M A, I would say; soundcard and external MIDI device in one.
(I think the Buran soundbank is way better than the unofficial SC soundbank.. SC is quite a bit overrated IMO)
Reply 7 of 18, by rishooty
I'm sure the extigy would run as a regular DAC no problem. I'm just pretty sure that you need creative's drivers in order to use ALchemy and mess with soundfonts.
TBH this is what I was leaning towards. Either just getting the X3M, or getting an X3M and a X-Fi Go Pro! to switch between them as I need midi+good DAC or EAX+CMSS.
As for the buran soundbank, I do like it a lot. It kinda reminds me of Arachno. I just hate that Doom Engine games just never quite sound right to me on anything other than an SC-55-Like. For example, e1m1 - at dooms gate just has VERY echoey and heavy guitars: https://soundcloud.com/user-470084971/doom-e1 … at-dooms-gate-3
Reply 8 of 18, by Srandista
Just be careful, if you would go for Dreamblaster to buy X3MA, since X3MB cannot be used as external sound card.
Reply 9 of 18, by appiah4
Those recordings are by me. I have since then altered the EQ preset used in that recording so that it sounds less boxy and has less reverb/chorus.
http://serdaco.com/downloads/X2/X2_SoundbankP … PPIAH4_v2_0.DXP
I don't have recordings at hand but it sounds punchier and drier.
Reply 10 of 18, by rishooty
Ohh nice! Yeah I'll probably just get the X3MB. It does look like the original X-Fi Go! and X-Fi Surround are in fact hardware accelerated. The later dacs, such as the Play 3 or X G1 7.1 do support alchemy, but I'm pretty sure it's software accelerated. I looked at the list of EAX games and it seems like near every game either has a solution or has been remade in some capacity, so I'd rather not spend $50 on something I'll rarely use. At least the X3MB is also a modern/decent 24-bit DAC. Thanks everyone!
Reply 11 of 18, by Srandista
Again, X3MB cannot be used as a USB sound card, you have to buy X3MA.
Reply 13 of 18, by t9999clint
OK, so looks like your asking for a lot of stuff here....
Fist off what OS you using this with?
If it's Windows 10, than hardware acceleration doesn't matter as audio based hardware acceleration isn't allowed in operating systems past Vista. It's ALL software emulated now.
Just get a good quality usb dac, don't worry about "3D" this or "EAX" that as it's all either borked in Windows 10 or not as good as the Dolby Atmos one that's built into Win10 (It has something like a $5 licencing fee though).
EAX is sadly pretty broken in Win10 across the board. It does work in somegames, but it's not quite the same as true EAX in Win XP.
MIDI in windows 10 is pretty easy, just use LoopMidi and Falcosoft MIDIPlayer. It sounds better than coolsoft does, and it'll work with .vst plugins like the Yamaha XG50 and the Roland VirtualSoundCanvas synths. Those sound 99% the same as the real things, and are MILES better than the SC-55 soundfont.
X3M is pretty handy for easy of use though, so that's still pretty valuable there.
Hardware acceleration or Hardware Based MIDI devices are really only worth the money for Operating Systems that are XP or Lower.
Don't get me wrong though. Hardware MIDI devices are fun to play with and they'll give you a sound that you just can't replicate in software, so I'll never discourage you from getting one. I'm just saying that they're not really needed on newer OSes anymore.
My Youtube Channel: https://www.kor.ninja/
My Soundfont Project: K.O.R. Soundfont Project V.5.0
My Soundcloud Page: https://soundcloud.com/clint-theriault
Reply 14 of 18, by appiah4
I'm not sure what the rationale here is; Coolsoft VirtualMIDISynth sounds just the same as Falcosoft MIDIPlayer when using soundfonts to me. As for VST plugins, yeah if you want to use those then the setup you offer is a good alternative, but the XG and SC VSTs are not necesserily better than what 1GB+ SF2s like Musyng Kite can make your game sound, so they are not objectively 'better', but can offer a more authentic sound I suppose. Bu then if you want authentic SC-55 you may as well get a real soundcanvas, as the SC VST is (IMO) horrendously expensive anyway ($125 wtf..) and I would rather buy an X3M for less than that price.
Reply 15 of 18, by t9999clint
appiah4 wrote:
I'm not sure what the rationale here is; Coolsoft VirtualMIDISynth sounds just the same as Falcosoft MIDIPlayer when using soundfonts to me. As for VST plugins, yeah if you want to use those then the setup you offer is a good alternative, but the XG and SC VSTs are not necessarily better than what 1GB+ SF2s like Musyng Kite can make your game sound, so they are not objectively 'better', but can offer a more authentic sound I suppose. Bu then if you want authentic SC-55 you may as well get a real soundcanvas, as the SC VST is (IMO) horrendously expensive anyway ($125 wtf..) and I would rather buy an X3M for less than that price.
Falcosoft has better compatibility with the different MIDI standards. It's also better at pitch bends and certain DSP effects. The difference is subtle but it's there.
A 1gb soundfont will easily beat those .vst's but that's not what I was comparing it too. I was comparing it to the SC-55 soundfont, which sound's pretty weird IMHO.
My main soundfont project is a really good one to use for games. (It's 2GB+ large)
the Yamaha vst is abandonware and fairly easy to find. The Roland one I think is only available now as a monthly subscription. But there's a Demo of it floating around if you'd like to try it out.
The Roland .vst does a far better job at SC-55 emulation than a X3M is capable of so again that's not exactly a fare comparison, and compared to the price of a real SC-8850 $125 isn't that bad. (I agree that it's still not worth it)
For SC-55/88, I agree your probably better off finding a real roland synth if you're going for accuracy.
Reply 16 of 18, by gdjacobs
What are the real terms under which it's licensed (abandonware isn't legally existent)?
Reply 17 of 18, by t9999clint
That's actually a very good point. It's still a commercial product, it's just one Yamaha doesn't sell anymore.
There was a version of it that they gave away for free, I'm not sure if that included the .vst though. (I think it was included with FF8)
Reply 18 of 18, by gdjacobs
Wasn't a version also bundled with a few different sound cards and apparently Toshiba laptops as well?
It's certainly widely available in driver cds and such, so I don't think we have to worry too much in passing this around, but we're probably depending a bit on the grace of Yamaha and the licensees to keep doing so.
