First post, by Intel486dx33
Does anyone know anything about this Sound Blaster 16 card ?
It is a CT1770 with Adaptec SCSI.
What driver package should I use to install in DOS/Win3.11 ?
It has a Yamaha OPL3 too.
Do I need a driver for the SCSI CDROM to work ?
Or do I just need to configure the onboard SCSI jumpers ?
Reply 1 of 14, by derSammler
Similar to an IDE CD-ROM, you need a driver in your config.sys. For SCSI, that is an ASPI CD driver. For that to work, you also need to load the ASPI interface driver for the SCSI chipset. You also need to load MSCDEX like with any other drive. Problem is, since you need more stuff to load (ASPI layer), an SCSI CD-ROM will eat up more precious memory under DOS.
ps: you can use the Win9x boot floppy to grap all files you need, it has support for SCSI CD-ROM drives.
pps: why is this in "Sound"?
http://retro-net.de/blog.html
Reply 2 of 14, by Intel486dx33
Because it is a sound card ?
I think it came with Adaptec EZ SCSI install diskette for DOS.
Which SB16 install package has support for the Yamaha OPL3 and Win3x apps ?
I don’t have these install diskettes but this is the software it came with.
Reply 3 of 14, by derSammler
But your question was mainly about SCSI.
You really don't need the Adaptec software, it installs lots of unneeded crap anyway. As wrote before, grab the files from a Win9x boot disk. You need aspi4dos.sys and aspicd.sys (file names may differ).
Reply 4 of 14, by skitters
I bought one of these ct1770 cards along with a compatible SCSI CD drive over 10 years ago from a guy on eBay.
I finally got it working using a set of DOS drivers on driverguide, but that was over 10 years ago.
Anyway, if it's at all helpful, here are the autoexec.bat and config.sys from the computer that show the names of the SCSI drivers that were loaded.
autoexec.bat
@ECHO OFF SET SOUND=C:\SB16 SET BLASTER=A220 I5 D1 H5 P330 T6 SET MIDI=SYNTH:1 MAP:E C:\SB16\DIAGNOSE /S C:\SB16\MIXERSET /P /Q […]
@ECHO OFF
SET SOUND=C:\SB16
C:\SB16\DIAGNOSE /S
@ECHO OFF
PROMPT $p$g
PATH C:\DOS;C:\SB16
SET TEMP=C:\DOS\TEMP
LH C:\DOS\MSCDEX.EXE /D:MYCD /M:8 /V
CTMOUSE2.COM
config.sys
DEVICE=C:\SCSI\ASPI2DOS.SYS /D /Z rem DEVICE=C:\DOS\SETVER.EXE DEVICE=C:\DOS\HIMEM.SYS DEVICE=C:\DOS\EMM386.EXE NOEMS DOS=HIGH,U […]
DOS=HIGH,UMB
REM ** FILES=30
FILES=40
DEVICEHIGH=C:\SCSI\ASPICD.SYS /D:MYCD
Reply 5 of 14, by SirNickity
SCSI in DOS has always been really clumsy. You need either the specific driver disk for the hardware you have, or you can just install EZ-SCSI and be done with it. The installer is really good about finding all the supported chipsets and installing the right driver in config.sys. Far easier to do that, than to go and figure out which aspiX driver goes with which chip, and then figure out what parameters the driver supports and whether you need to supply any of them. I use version 5. Good for DOS, Win 3.x, Win95.
Aside from that, any SB16 package will cover the hardware north of the SCSI chipset.
Reply 7 of 14, by Anonymous Coward
CT1770 with ASP is the king of SB16.
Reply 8 of 14, by jaZz_KCS
So basically, a CT1740 (ASP soldered down out of the box) is the king of SB16 (if SCSI is not of interest) 😀
RiP wrote:
Does anyone have all of the latest CT1770 drivers for Dos, Win3.x, Win9x ? 😕
See attachments.
    sbw9xup.exe
    311.97 KiB
    10 downloads
    Win9x driver update
    sbbasic.exe
    1.15 MiB
    13 downloads
    DOS+Win3.1
Reply 10 of 14, by jaZz_KCS
It doesnt have a BIOS rom that hooks on boot-up.
And you probably have the jumper that controls whether the Speaker-Out is amplified or not set to "no". Which results in it becoming a Line-Out that is not amplified and doesn't adhere to the volume knob.
Reply 11 of 14, by RiP
You're right, thanks 😎
It has AMAZING sound quality o.0
Reply 12 of 14, by Intel486dx33
jaZz_KCS wrote:
So basically, a CT1740 (ASP soldered down out of the box) is the king of SB16 (if SCSI is not of interest) :) […]
See attachments.
Thanks, My IBM PS/1 multimedia edition originally came with the CT-1740 and creative/Matsushita 2x CDROM.
The CT-1740 has a Panasonic interface built in. It's NOT IDE.
Reply 14 of 14, by greg2002
OK, I received a Sound Blaster 16 CT1700 today, and was successful with the installation !
This was a DOS only installation.
First I ran the SB16 install program with all the defaults, then I ran Adaptec EZ-SCSI install program and it found the identified the Adaptec chip as:
Adaptec AIC-6360 Family Adapter Port 340h
I let the install program do the rest and it added these lines to my startup files:
config.sys
device=c:\scsi\ASPI2DOS.sys /D /Z /Q9
device=c:\scsi\ASPICD.sys /D:ASPICD0
autoexec.bat
c:\scsi\mscdex.exe /D:ASPICD0 /M:12 /L:G
Just FYI for those searching for answers !
Greg
