First post, by maxtherabbit
Working Great (AWEUTIL emulation):
Martian memorandum (mt32)
Rise of the dragon (mt32)
Kyrandia 2 Hand of Fate (gm)
The incredible machine (gm)
Day of The Tentacle (gm)
Island of Dr. Brain (gm)
Charlie The Duck (gm)
Problems:
Fate of Atlantis (mt32): music is suuuuper quiet, can fight the mixer to get it to a reasonable level, but it still sounds a bit off (custom instruments?)
Hocus pocus (gm): sounds good but music will eventually "crash" and stop playing. This can be avoided by disabling digital sound FX.
Legend of Kyrandia 1 (mt32): BGM sounds great but the sound effects sound off, doesn't seem to be a way to choose different devices for them in the setup
Startrek 25th CDROM (mt32): sounds a bit odd, notes stick (custom instruments?)
Startrek Judgement Rites CDROM (mt32): sounds a bit odd, notes stick (custom instruments?)
Tyrian2k (gm): just selecting MIDI on port 330 crashed the setup utility - occurs irrespective of AWEUTIL being loaded
ORIGINAL POST CONTENT FOLLOWS
Is there a list somewhere of games which do not use a DOS extender and run in real mode, which also support either the default MT-32 instrument set or General MIDI? I've just setup an AWE64 card, and would like to play around with the emulation to see how it sounds. I realise the prevailing opinion on here is that it's worthless and not worth the time, but I'm determined to give it a try anyway.
So far I've confirmed Indiana Jones and the Fate of Atlantis works with the MT-32 emulation, and sounds to me as though it's using the correct instruments (though I'm not super familiar with the game's soundtrack)
Also the following SCI games support the use of General MIDI emulation with the help of a patch (AWESOL.ZIP):
Conquests of the Longbow
EcoQuest 1
EcoQuest 2
Freddie Pharkas, Frontier Pharmacist
Hoyle's Book of Games 3
Hoyle Classic Card Games
Island of Dr. Brain
King's Quest 6
Laura Bow 2
Leisure Suit Larry 1 (VGA Version)
Leisure Suit Larry 5
Leisure Suit Larry 6 (Diskette version only)
Mixed-Up Fairy Tales
Quest for Glory 1 (VGA Version)
Quest for Glory 3
Slater & Charlie Go Camping
Space Quest 1 (VGA version)
Space Quest 4
Space Quest 5
Reply 2 of 42, by dionb
Civilization (1) supports MT-32 and I believe it just uses the default instrument set - at least it sounds pretty similar on my Yamaha MU50 in MT-32 mode as on my MT-32.
Reply 4 of 42, by maxtherabbit
Just tried Day of the Tentacle. It work with the MT-32 emulation, but it sounds odd. General MIDI emulation sounded much better. I'm guessing this is a game that programs different instruments on the MT-32?
Reply 5 of 42, by matze79
SoftMPU has same limitation, so you can look into softmpu Games compatiblity list.
Reply 6 of 42, by foil_fresh
monkey island 1 and 2 worked
edit: actually cant remember if it sounded proper or not, but i do recall using mt32 on a full playthrough of monkey island on an SB Live sounding really good, cant see how it would be much different.
Reply 7 of 42, by maxtherabbit
I've always read that MI1 uses the default MT-32 instrument set, but I only have the CD version so I wasn't able to verify that
I think MI2 programs different patches for MT-32, but it should work with General MIDI emulation
Reply 8 of 42, by Grzyb
Prehistorik
Prince of Persia
Silpheed
Stunts
Test Drive III
And many more:
https://www.mobygames.com/browse/games/dos/tic,1/ti,35/
and select the years before 1993, as that was when DOS4GW became common.
Żywotwór planetarny, jego gnijące błoto, jest świtem egzystencji, fazą wstępną, i wyłoni się z krwawych ciastomózgowych miedź miłująca...
Reply 9 of 42, by maxtherabbit
Grzyb wrote:
Prehistorik Prince of Persia Silpheed Stunts Test Drive III […]
Prehistorik
Prince of Persia
Silpheed
Stunts
Test Drive III
And many more:
Problem is there is no way of knowing if they use the default instrument set or not. AWE can only emulate the default instruments, if the games program different patches it will sound all wrong.
Reply 10 of 42, by Spikey
With the AWE32, since it is a GM bank using card, you should be able to play any GM game like many Sierra ones mentioned in the OP without any driver, unless I'm missing something.
Also:
Police quest 1 - GM
This is actually a MT-32 game, but has the MIDI's converted to GM on the fly for basic level support.
Reply 11 of 42, by Jo22
I know of two more types of Real-Mode games supporting MT-32..:
Magnetric Scrolls advanture games series (i.e. Wonderland)
Frederik Pohl's Gateway series
Not sure if they use factory-settings for MT-32, however.
They may also use extra SFX from the CM-32L/LAPC-I synths.
Reply 12 of 42, by Tempus
SOMI CD-version uses CD-music.
Akumajō Dracula: Belmont's Theme Roland MT-32 | Yamaha YM2151
Reply 13 of 42, by maxtherabbit
obviously, that's why I said I could not test the MT-32 instrumentation with my CD version
Reply 14 of 42, by foil_fresh
Grzyb wrote:
Stunts
ahh!!! i never thought to try this out. stunts has great fm music... cant wait to see if the mt32 is as cool as i can imagine 😁
i'll try:
Sam N Max
Monkey Island 1 and 2
Return of the Phantom
Xcom/Xcom TFTD
I remember Jurassic Park (1993 Ocean) worked with the MT-32 set (because neither my AWE64 or Yamaha PCI card can make the SB sound effects work, they all screech and dont sound good, in fact, its an awful sound that makes eardrums bleed... maybe it's an issue with playing a 386 game on a pentium mmx)
Reply 15 of 42, by krcroft
Here are 171 titles queried from my personal play-testing collection of roughly 600 titles. I've listed the midi-type I'm using, however the game might support others.
I've listed the as-configured device, which I've selected trying to use the one truest to what the composer might have used or as recommended by the community; if anyone sees a better choice please flag it. (Because of this preference, realmode GM-capable games that I've configured with OPL* synthesis won't be listed because my script can't differentiate those).
  • 4D Sports Boxing (mt32)
  • A-10 Tank Killer (mt32)
  • Aces of the Pacific (mt32)
  • AD&D Dragonlance I Champions of Krynn (mt32)
  • AD&D Dragonlance III The Dark Queen of Krynn (mt32)
  • AD&D Forgotten Realms II Curse of the Azure Bonds (mt32)
  • AD&D Forgotten Realms III Secret of The Silver Blades (mt32)
  • Air Duel 80 Years of Dogfighting (gm)
  • Another World (mt32)
  • Armored Fist 1 (mt32)
  • A-Train (mt32)
  • B-17 Flying Fortress (mt32)
  • Battle Chess I (mt32)
  • BattleTech II The Crescent Hawk's Revenge (mt32)
  • Beneath a Steel Sky (mt32)
  • Betrayal at Krondor (gm)
  • Budokan The Martial Spirit (mt32)
  • Caesar I (gm)
  • Cannon Fodder 1 (mt32)
  • Cannon Fodder 2 (mt32)
  • Castles II Siege & Conquest (sc55)
  • Centurion Defender of Rome (mt32)
  • Chip's Challenge (mt32)
  • Comanche Maximum Overkill (mt32)
  • Companions of Xanth (mt32)
  • Conquests of Camelot The Search for the Grail (mt32)
  • Conquests of the Longbow The Legend of Robin Hood (mt32)
  • Cruise for a Corpse (mt32)
  • Curse of Enchantia (mt32)
  • Dig It! (gm)
  • Dune II The Building of a Dynasty (sc55)
  • Elite II Frontier (mt32)
  • Elite I Plus (mt32)
  • Epic (mt32)
  • Eric the Unready (mt32)
  • F-117A Nighthawk Stealth Fighter 20 (mt32)
  • F-15 Strike Eagle III (mt32)
  • Face Off! (mt32)
  • Flashback The Quest for Identity (mt32)
  • Fleet Defender (mt32)
  • Ghostbusters II (mt32)
  • Goblins Quest 3 (mt32)
  • Gods (mt32)
  • Gunship 2000 (mt32)
  • Heart of China (mt32)
  • Hired Guns (mt32)
  • Hocus Pocus (gm)
  • Hoyle Official Book of Games 1 (mt32)
  • Hoyle Official Book of Games 2 (mt32)
  • Hoyle Official Book of Games 3 (mt32)
  • Hoyle's Classic Card Games (gm)
  • Indiana Jones and the Fate of Atlantis (mt32)
  • Innocent Until Caught (mt32)
  • It Came From The Desert (mt32)
  • Janes Combat Simulations US Navy Fighters 97 (gm)
  • Jimmy White's Whirlwind Snooker (mt32)
  • Jones in the Fast Lane (mt32)
  • King's Quest I (1990) Quest for the Crown (mt32)
  • King's Quest IV The Perils of Rosella (mt32)
  • King's Quest V Absence Makes the Heart Go Yonder! (mt32)
  • King's Quest VI Heir Today, Gone Tomorrow (sc55)
  • Knights of the Sky (mt32)
  • Lands of Lore The Throne of Chaos (sc55)
  • Leisure Suit Larry I (1991) in the Land of the Lounge Lizards (mt32)
  • Leisure Suit Larry II Goes Looking for Love (In Several Wrong Places) (mt32)
  • Leisure Suit Larry III Passionate Patti in Pursuit of the Pulsating Pectorals (mt32)
  • Leisure Suit Larry V Passionate Patti Does a Little Undercover Work (mt32)
  • Lemmings 2 The Tribes (mt32)
  • Lemmings 3D (gm)
  • Les Manley In - Lost In LA (mt32)
  • Lightspeed (mt32)
  • Lode Runner The Legend Returns (gm)
  • Lolly Pop (mt32)
  • Loom (mt32)
  • Lotus The Ultimate Challenge (mt32)
  • Lure of the Temptress (mt32)
  • Maniac Mansion I (gm)
  • Mario Teaches Typing (mt32)
  • MechWarrior 1 (mt32)
  • Megarace (gm)
  • Might and Magic III Isles of Terra (mt32)
  • Might and Magic IV World (Clouds and Darkside) of Xeen (mt32)
  • Might and Magic VI Swords Of Xeen (gm)
  • Monkey Island II LeChuck's Revenge (mt32)
  • Monkey Island I The Secret of Monkey Island (mt32)
  • Noctropolis (gm)
  • Oil's Well (mt32)
  • Overlord (mt32)
  • Police Quest I (1992) In Pursuit of the Death Angel (mt32)
  • Police Quest III The Kindred (mt32)
  • Police Quest II The Vengeance (mt32)
  • Populous I (mt32)
  • Predator 2 (mt32)
  • Prehistorik 1 (mt32)
  • Prince of Persia 2 The Shadow & The Flame (sc55)
  • Prophecy of the Shadow (mt32)
  • Pushover
  • Quest For Glory I (1989) So You Want To Be A Hero? (mt32)
  • Quest For Glory I (1992) So You Want To Be A Hero? (mt32)
  • Quest For Glory III Wages of War (gm)
  • Quest For Glory II Trial By Fire (mt32)
  • Rampart (mt32)
  • Realms (mt32)
  • Red Baron (mt32)
  • Return to Zork (mt32)
  • Rex Nebular and the Cosmic Gender Bender (mt32)
  • Rise of the Dragon (mt32)
  • Risky Woods (mt32)
  • Rules of Engagement 1 (mt32)
  • Sango Fighter (gm)
  • Sensible World Of Soccer 96-97 (mt32)
  • Sid Meier's Civilization (mt32)
  • Sid Meier's Colonization (sc55)
  • Sid Meier's Pirates! Gold (mt32)
  • Sid Meier's Railroad Tycoon (mt32)
  • Silpheed (mt32)
  • SimAnt The Electronic Ant Colony (mt32)
  • SimCity (mt32)
  • SimCity Classic (gm)
  • Simon the Sorcerer (mt32)
  • Ski or Die (mt32)
  • Space Quest I (1991) The Sarien Encounter (mt32)
  • Space Quest III The Pirates of Pestulon (mt32)
  • Space Quest IV The Time Rippers (mt32)
  • Space Quest V The Next Mutation (gm)
  • Speedball 2 Brutal Deluxe (mt32)
  • Spellcasting 101 Sorcerers Get All The Girls (mt32)
  • Spellcasting 201 The Sorcerer's Appliance (mt32)
  • Spellcasting 301 Spring Break (mt32)
  • Star Control I (mt32)
  • Star Crusader (sc55)
  • Star Trek (1992) 25th Anniversary (mt32)
  • Star Wars X-Wing (sc55)
  • Stellar 7 II, Nova 9 Return of Gir Draxon (mt32)
  • Stronghold (mt32)
  • Stunt Island (mt32)
  • Subwar 2050 (mt32)
  • Supaplex (mt32)
  • Sword of the Samurai (mt32)
  • Terminator (1992) 2029 Operation Scour (gm)
  • Terminator (1993) Rampage (gm)
  • Test Drive III The Passion (mt32)
  • Tetris Classic (mt32)
  • Tex Murphy Martian Memorandum (mt32)
  • The Amazon Trail (mt32)
  • The Chaos Engine (mt32)
  • The Incredible Machine 1 (mt32)
  • The Incredible Machine 2 (mt32)
  • The Legacy Realm of Terror (mt32)
  • The Legend of Kyrandia I (mt32)
  • The Legend of Kyrandia II Hand of Fate (gm)
  • The Lost Vikings (mt32)
  • Thexder II Fire Hawk, The Second Contact (mt32)
  • Tongue of the Fatman (mt32)
  • Transport Tycoon Deluxe (gm)
  • Tyrian 2000 (gm)
  • Ugh! (gm)
  • Ultima 1 The First Age of Darkness (gm)
  • Ultima 6 The False Prophet (gm)
  • Ultima Worlds of Adventure 2 Martian Dreams (mt32)
  • Veil of Darkness (mt32)
  • Warlords I (gm)
  • Where in Space Is Carmen Sandiego? (gm)
  • Where in the USA Is Carmen Sandiego? (gm)
  • Where in the World Is Carmen Sandiego? (mt32)
  • Where in Time Is Carmen Sandiego? (gm)
  • Wing Commander Academy (mt32)
  • Wing Commander I (mt32)
  • Wing Commander II Vengeance of the Kilrathi (mt32)
  • Wizardry Crusaders of the Dark Savant (mt32)
  • Zeliard (mt32)
Reply 17 of 42, by krcroft
maxtherabbit wrote:
Wow that's great, thanks krcroft
Gladly; definitely an interesting question! 😀
Here are 545 entries queried from eXo's current set of 7,000 titles. You'll note that some games predate even the MT32: these can be assumed to contain community patches to support GM, such as the early Ultima games.
Although I haven't played/tested a good portion of these, the list is interesting in that it seem to (subjectively) correlate with "higher-quality" games that might have had more resources (time/people/budget) poured into them. So for me, I'll probably dabble in some that are new to me.
  • 1830 Railroads & Robber Barons (1995)
  • 3-D Body Adventure (1994)
  • 3D Bomber (1998)
  • 3D Lemmings Winterland (1995)
  • 4-D Boxing (1991)
  • 4D Sports Tennis (1990)
  • 7th Guest, The (1993)
  • A-10 Tank Killer (1989)
  • ABC Wide World of Sports Boxing (1991)
  • Adventures of Maddog Williams, The (1992)
  • Adventures of Willy Beamish, The (1991)
  • Air Duel 80 Years of Dogfighting (1993)
  • Alien Breed (1993)
  • Alien Olympics (1994)
  • Al Pond 2 - Island Quest (2007)
  • Altered Destiny (1990)
  • Amazon - Guardians of Eden (1992)
  • Amazon Trail (1993)
  • America Adventure (1993)
  • American Gladiators (1992)
  • An American Tail - Fievel Goes West (1993)
  • Ancient Art of War in the Skies (1992)
  • ANIMAC (1991)
  • Apachacha (1993)
  • Are We There Yet (1991)
  • Armored Fist (1994)
  • Armour-Geddon (1992)
  • ATAC - The Secret War Against Drugs (1992)
  • B-17 Flying Fortress (1992)
  • Back to the Future Part II (1990)
  • Back to the Future Part III (1991)
  • Back to the Moon (1996)
  • Bad Blood (1990)
  • Baoxiao Duobiqiu (1993)
  • Bard's Lore II, The - The Dark Tower (1998)
  • Bard's Lore, The - The Warrior & The Dragon (1998)
  • Bard's Quest, The - Dungeons of the Unknown (1994)
  • Bard's Tale 3, The - Thief Of Fate (1990)
  • Bard's Tale Construction Set, The (1991)
  • Battle Master (1991)
  • Battle of the Martial Arts (1994)
  • BattleStar (1994)
  • BattleTech - The Crescent Hawk's Revenge (1990)
  • Beneath a Steel Sky (1994)
  • Berenstain Bears, The - Treehouse Classroom (1994)
  • Betrayal at Krondor (1993)
  • Beverly Hillbillies, The (1993)
  • Beyond Castle Wolfenstein (1985)
  • Biing! Sex, Intrigue and Scalpels (1995)
  • Bill Elliott's NASCAR Challenge (1990)
  • Billy the Kid (1990)
  • Birds of Prey (1992)
  • Blood Bowl (1995)
  • Bloodnet (1993)
  • Bloodwych (1989)
  • Blue Force (1993)
  • Bluntman and Chronic P.C. Version (2003)
  • Bodyworks Voyager - Mission in Anatomy (1994)
  • Bo Jackson Baseball (1991)
  • Box Ranger (1992)
  • Bram Stoker's Dracula (1993)
  • Breach 2 (1990)
  • Bridge Deluxe 2 With Omar Sharif (1996)
  • Bridge Master (1992)
  • BuBu (1995)
  • Buck Rogers - Matrix Cubed (1992)
  • Budokan The Martial Spirit (1989)
  • Bug Adventure (1994)
  • Bumping Warrior (1994)
  • Bumpy's Arcade Fantasy (1992)
  • Cadaver - The Payoff (1991)
  • Campaign 2 (1993)
  • Cannon Fodder (1993)
  • Captain Bible in the Dome of Darkness (1994)
  • Car & Driver (1992)
  • Castles (1991)
  • Castles 2 - Siege & Conquest (1992)
  • Castles - The Northern Campaign (1991)
  • Centurion - Defender of Rome (1990)
  • Challenge of the Five Realms (1992)
  • Champions of Krynn (1990)
  • Charlie the Duck (1996)
  • Circuit's Edge (1990)
  • Clive Barker's Nightbreed - The Action Game (1990)
  • Clive Barker's Nightbreed - The Interactive Movie (1990)
  • Code - Europe (1993)
  • Codename ICEMAN (1989)
  • Cold Dreams (1995)
  • Comanche CD (1994)
  • Command HQ (1990)
  • Companions of Xanth (1993)
  • Conquests of Camelot - The Search for the Grail (1990)
  • Conquests of the Longbow - The Legend of Robin Hood (1991)
  • Contraption Zack (1992)
  • Corporation (1991)
  • Creepers (1992)
  • Creepers Christmas (1992)
  • Crisis in the Kremlin (1992)
  • Cruise for a Corpse (1991)
  • Crusade (1995)
  • Curse of Enchantia (1992)
  • Curt's Quest (2007)
  • Cyberwar (1994)
  • Daemonsgate (1992)
  • Dangerous Dave in the Haunted Mansion (1991)
  • Dark Half, The (1992)
  • Dark Queen of Krynn, The (1992)
  • Dark Universe (1995)
  • Daughter of Serpents (1992)
  • David Leadbetter's Greens (1991)
  • David Wolf - Secret Agent (1989)
  • Day 3, The - Dragon Force (1993)
  • Day 4, The - Icarus (1994)
  • Day of the Tentacle (1993)
  • Day of the Viper (1989)
  • Days of Thunder (1990)
  • Deathbringer (1992)
  • Deathtrack (1989)
  • Defender of Freedom (1992)
  • Defender of the Faith - The Adventures of David (1992)
  • Deluxe Trivial Pursuit (1992)
  • Desert Strike - Return to the Gulf (1994)
  • Destination Mars! (1991)
  • Detritus - The Daemon's Quest (1996)
  • Detroit (1993)
  • Dinopark Tycoon (1993)
  • Discoverers, The (1994)
  • Dominium (1992)
  • Druid - Daemons of the Mind (1995)
  • Dune (1992)
  • Dune 2 - The Building of a Dynasty (1992)
  • Dungeon Hack (1993)
  • Eagle Eye Mysteries (1993)
  • Eagle Eye Mysteries in London (1994)
  • Earl Weaver Baseball II (1991)
  • EcoQuest 1 - The Search for Cetus (1991)
  • EcoQuest 2 - Lost Secret of the Rainforest (1993)
  • Elder Scrolls, The - Arena (1994)
  • Elf (1992)
  • Elite Plus (1991)
  • Elvira 2 - The Jaws of Cerberus (1991)
  • Elvira - Mistress of the Dark (1990)
  • Empire 2 - The Art of War (1995)
  • Epic (1992)
  • Eric the Unready (1993)
  • Evasive Maneuvers (1994)
  • Even More Incredible Machine, The (1993)
  • Exterminator (1990)
  • Eye of the Beholder III - Assault on Myth Drannor (1993)
  • F-14 Tomcat (1990)
  • F-15 Strike Eagle III (1992)
  • Face Off! (1989)
  • Fast Attack High Tech Submarine Warfare (1996)
  • Fates of Twinion (1993)
  • Father World (1994)
  • Fighter Bomber - Advanced Mission Disc (1990)
  • Flashback - The Quest for Identity (1993)
  • Fleet Defender (1994)
  • Flight of the Amazon Queen (1995)
  • Four Crystals of Trazere, The (1992)
  • Fox Ranger 2 (1993)
  • Freakin Funky Fuzzballs (1990)
  • Freddy Pharkas Frontier Pharmacist (1993)
  • Front Page Sports Football (1992)
  • Front Page Sports Football Pro (1993)
  • Fun 'N Games Deluxe (1995)
  • Fun Seeker's Guide to Eastern Madera County (1991)
  • Game of Harmony, The (1990)
  • Gargoyle Medieval Pack (1995)
  • Gary Grigsby's Pacific War (1992)
  • Gary Grigsby's War in Russia (1993)
  • Gateway (1992)
  • Gateway 2 - Homeworld (1993)
  • Gateworld (1993)
  • Gazza II (1991)
  • Get Lost! (1996)
  • Ghostbusters II (1989)
  • Global Effect (1992)
  • Goal! (1993)
  • Gods (1991)
  • Golden Eagle (1991)
  • Grandest Fleet, The (1994)
  • Grandmaster Chess (1993)
  • Grandmaster Chess (CD-ROM Edition) (1993)
  • Grand Prix Unlimited (1992)
  • Gunblaze (1994)
  • Gunboat (1990)
  • Gunship 2000 (CD-ROM Edition) (1993)
  • Hard Nova (1990)
  • Heart of China (1991)
  • Heimdall (1992)
  • Hell - A Cyberpunk Thriller (1994)
  • Hero Quest (1992)
  • Hexx - Heresy of the Wizard (1994)
  • Hidden Below, The (1994)
  • Hired Guns (1993)
  • Home Alone (1991)
  • Home Alone 2 - Lost in New York (1992)
  • Homey D Clown (1993)
  • Hoverforce (1990)
  • Hoyle Classic Card Games (1993)
  • Hoyle Official Book of Games - Volume 1 (1989)
  • Hoyle Official Book of Games - Volume 2 (1990)
  • Hoyle Official Book of Games - Volume 3 (1991)
  • Hubie (1996)
  • Humans 1 & 2 (1993)
  • Humans 3 - Evolution - Lost in Time (1995)
  • H.U.R.L. (1995)
  • Hyperspeed (1991)
  • IAS (1994)
  • Immortal, The (1991)
  • Imperium (1990)
  • Incredible Machine 2, The (1994)
  • Incredible Machine, The (1993)
  • Indiana Jones and the Fate of Atlantis (1992)
  • Indianapolis 500 The Simulation (1989)
  • Inferno (1994)
  • Innocent Until Caught (1993)
  • International Sensible Soccer (1994)
  • Invincible Fighter (1994)
  • Island of Dr. Brain (1992)
  • It Came from the Desert (1990)
  • Jack Nicklaus Golf & Course Design - Signature Edition (1992)
  • Jack Nicklaus' Unlimited Golf & Course Design (1990)
  • James Bond 007 - The Stealth Affair (1990)
  • Jeopardy! New Sports Edition (1988)
  • Joe Montana Football (1990)
  • John Madden Football II (1991)
  • Jones in the Fast Lane (Enhanced CD-ROM) (1992)
  • J.R.R. Tolkien's The Lord of the Rings Vol 1 (1990)
  • J.R.R. Tolkien's The Lord of the Rings Vol 2 (1991)
  • Jump Jet (1992)
  • Jurassic Park (1993)
  • Kasparov's Gambit (1993)
  • Keef the Thief (1989)
  • Ken's Labyrinth (1993)
  • Kentris (1991)
  • KGB (1992)
  • KGB Conspiracy (1992)
  • Killing Cloud (1991)
  • King's Quest I - Quest for the Crown VGA (1990)
  • King's Table - The Legend of Ragnarok (1993)
  • Knights of the Sky (1990)
  • Kronolog - The Nazi Paradox (1993)
  • Lakers versus Celtics and the NBA Playoffs (1989)
  • L.A. Law - The Computer Game (1992)
  • Land Of Devastation (1996)
  • Lands of Lore - The Throne of Chaos (1993)
  • Last Hero in China (1995)
  • Laura Bow 1 - The Colonel's Bequest (1989)
  • Laura Bow 2 - The Dagger of Amon Ra (1992)
  • Leather Goddesses of Phobos 2 (1992)
  • Legacy - Realm of Terror (1993)
  • Legend of Kyrandia Book 1 (1992)
  • Legend of Kyrandia Book 2 - The Hand of Fate (1993)
  • Leisure Suit Larry 1 - Land of the Lounge Lizards VGA (1991)
  • Leisure Suit Larry 2 - Goes looking for Love in Several Wrong Places (1988)
  • Leisure Suit Larry 3 - Passionate Patti in Pursuit of the Pulsating Pectorals (1989)
  • Leisure Suit Larry 5 - Passionate Patti Does a Little Undercover Work (1991)
  • Lemmings 3D (1995)
  • Les Manley in - Lost in LA (1991)
  • Les Manley in - Search for the King (1990)
  • Lexi-Cross (1991)
  • Lightspeed (1990)
  • Line in the Sand, A (1992)
  • LineWars 2 (1994)
  • Litil Divil (1993)
  • Little People Farm (1992)
  • Little People Main Street (1992)
  • Living Ball (1995)
  • Llamatron - 2112 (1992)
  • Lode Runner - The Legend Returns (1994)
  • Lollypop (1994)
  • Loopz (1990)
  • Lost Vikings, The (1993)
  • Lotus - The Ultimate Challenge (1993)
  • Low Blow (1990)
  • Lucky's Casino Adventure (1993)
  • Lure of the Temptress (1992)
  • M1 Tank Platoon (1989)
  • Magic Candle 2, The - The Four and Forty (1991)
  • Magic Pockets (1992)
  • Man Enough (1994)
  • Manhole Enhanced, The (1992)
  • Mario Andretti's Racing Challenge (1991)
  • Mario is Missing! Deluxe (1993)
  • Mario's Early Years Collection (1994)
  • Mario's Game Gallery (1995)
  • Mario Teaches Sums (1994)
  • Mario Teaches Typing (1992)
  • Martian Memorandum (1991)
  • Master Won Liu 3D (1996)
  • MechWarrior (1989)
  • Mega Force 2 (1995)
  • Mega Math (1992)
  • MegaTraveller 2 - Quest for the Ancients (1991)
  • Merchant Prince (1993)
  • Miami Vice (1989)
  • Michael Jordan in Flight (1993)
  • Microcosm (1994)
  • MiG-29M Super Fulcrum (1991)
  • Might and Magic 3 - Isles of Terra (1991)
  • Might and Magic 4+5 - World of Xeen (1994)
  • Might and Magic 4 - Clouds of Xeen (1992)
  • Might and Magic 5 - Darkside of Xeen (1993)
  • Might and Magic - Swords of Xeen (1995)
  • Mike Ditka Ultimate Football (1991)
  • Mission Impossible (1991)
  • Mixed-Up Fairy Tales (1991)
  • Mixed-Up Mother Goose (1990)
  • Monkey Island 2 - LeChuck's Revenge (1991)
  • Monopoly Deluxe (1992)
  • Moonstone - A Hard Days Knight (1992)
  • Mr. Blobby (1994)
  • Mutanoid Word Challenge, The (1992)
  • My Own Stories (1993)
  • NFL (1992)
  • NFL 94 (1993)
  • NFL Coaches Club Football (1993)
  • NHL '94 (1993)
  • Nicky 2 (1993)
  • Nicky Boom (1992)
  • Ninja Gaiden II - The Dark Sword of Chaos (1991)
  • Noctropolis (1994)
  • Nova 9 - Return of Gir Draxon (1991)
  • Obitus (1991)
  • Oil's Well (1990)
  • Once Upon a Forest (1995)
  • One Step Beyond (1993)
  • Origamo (1994)
  • Out of This World (1991)
  • OverKill (1992)
  • Overlord (1990)
  • Overlord (1994)
  • Pacific Islands (1992)
  • Paku Paku (2011)
  • Paladin II (1992)
  • Pang (1992)
  • Penthouse - Hot Numbers Deluxe (1993)
  • PGA Tour Golf (1990)
  • Pickle Wars (1994)
  • Pinball Wizard 2000 (1995)
  • Pirates! Gold (1993)
  • Plan 9 From Outer Space (1992)
  • Planet's Edge - The Point of No Return (1991)
  • PlayMaker Football (1991)
  • Pocahontas (1995)
  • Pokso Bowling (1995)
  • Police Quest 1 - In Pursuit of the Death Angel VGA (1990)
  • Police Quest 2 - The Vengeance (1988)
  • Police Quest 3 - The Kindred (1991)
  • Populous (1989)
  • Power Drift (1990)
  • PowerMonger (1992)
  • Prehistorik (1991)
  • Premier Manager 2 (1993)
  • Prince of Persia (1990)
  • Prince of Persia 2 - The Shadow & The Flame (1993)
  • Princess Maker 2 (1993)
  • Prophecy 1 - The Viking Child (1991)
  • Prophecy of the Shadow (1992)
  • Pure Wargame, The (1995)
  • Pushover (1992)
  • Quarky & Quaysoo's Turbo Science (1992)
  • Quest for Glory II - Trial by Fire (1990)
  • Quest for Glory I - So You Want to be a Hero (1989)
  • Quest for Glory I - So You Want to be a Hero VGA (1992)
  • Quest for the Cheat, The (2007)
  • Race Drivin' (1992)
  • Rags to Riches The Financial Market Simulation (1993)
  • Raiden (1994)
  • Rallo Gump (1994)
  • Rampart (1992)
  • Rapid Assault (1995)
  • Red Baron (1990)
  • Red Crystal, The - The Seven Secrets of Life (1993)
  • Red Storm Rising (1989)
  • Rescue the Scientists (1994)
  • Resurrection - Rise 2 (1996)
  • Return of Medusa, The (1991)
  • Return of the Phantom (1993)
  • Return to Zork (1993)
  • Revenge of the Mutant Camels (1994)
  • Rex Nebular and the Cosmic Gender Bender (1992)
  • Ringworld - Revenge of the Patriarch (1992)
  • Rise of the Dragon (1990)
  • Risky Woods (1992)
  • Road Hog! (1995)
  • RoboCop 3 (1992)
  • Rocketeer, The (1991)
  • Rome - Pathway to Power (1993)
  • Ruins of Cawdor (1995)
  • Rules of Engagement (1991)
  • Sabre Team (1994)
  • Sam & Max Hit the Road (1993)
  • Sango Fighter (1993)
  • Sango Fighter 2 (1995)
  • Sargon 5 - World Class Chess (1991)
  • Savage Warriors (1995)
  • Sea Legends (1996)
  • Seal Team (1993)
  • Secret Codes of C.Y.P.H.E.R. - Operation Wildlife, The (1991)
  • Secret of Monkey Island, The (1990)
  • Sensible Soccer - European Champions - 92-93 Edition (1993)
  • Shadowlands (1993)
  • Shadow of Yserbius (1993)
  • Shadoworlds (1993)
  • Shadow Sorcerer (1991)
  • Shanghai II - Dragon's Eye (1990)
  • Sherlock Holmes - The Case of the Rose Tattoo (1996)
  • Sherlock Holmes - The Case of the Serrated Scalpel (1992)
  • Shuttle The Space Flight Simulator (1992)
  • Sid & Al's Incredible Toons (1993)
  • Sid Meier's Colonization (1994)
  • Sid Meier's Railroad Tycoon Deluxe (1993)
  • Siege (1992)
  • Silpheed (1988)
  • SimAnt - The Electronic Ant Colony (1991)
  • Simon the Sorcerer (1993)
  • Simpsons, The - Bart's House of Weirdness (1991)
  • Simpsons, The - Bart vs. the Space Mutants (1991)
  • Ski or Die (1990)
  • Slater & Charlie Go Camping (1993)
  • Snoopy's Game Club (1992)
  • Soldiers of Fortune (1994)
  • Solitaire's Journey (1992)
  • Soltys (1995)
  • Sorcerian (1990)
  • Space Crusade (1992)
  • Space MAX (1992)
  • Space Quest III - The Pirates of Pestulon (1989)
  • Space Quest I - The Sarien Encounter VGA (1991)
  • Space Quest IV - Roger Wilco and the Time Rippers (1991)
  • Space Quest V - The Next Mutation (1993)
  • Special Forces (1992)
  • Speedball 2 - Brutal Deluxe (1992)
  • Spellcasting 101 - Sorcerers Get All the Girls (1990)
  • Spellcasting 201 - The Sorcerers Appliance (1991)
  • Spellcasting 301 - Spring Break (1992)
  • SpellCraft - Aspects of Valor (1992)
  • Spelljammer - Pirates of Realmspace (1992)
  • Spirit of Excalibur (1990)
  • Spot (1990)
  • Spy Master (1994)
  • SSN-21 Seawolf (1994)
  • Star Control (1990)
  • Star Crusader (1994)
  • Starlord (1993)
  • Star Trek - 25th Anniversary (1992)
  • Star Trek - Judgement Rites (1993)
  • Star Wars X-Wing (Collector's CD-ROM) (1994)
  • Stellar 7 (1990)
  • Storybook Weaver (1992)
  • Street Fighter II (1992)
  • Street Rod (1989)
  • Strike Aces (1990)
  • Striker (1992)
  • Striker '95 (1995)
  • Stronghold (1993)
  • Stunt Island (1992)
  • Stunts (1990)
  • Subwar 2050 (CD-ROM) (1994)
  • Summoning, The (1992)
  • Supaplex (1991)
  • Super Beemger (1994)
  • Super Fighter (1993)
  • Super Samtong (1994)
  • Super Solvers Operation Neptune (1990)
  • Super Star Wars (1994)
  • Super Tetris (1991)
  • Synnergist (1996)
  • Taito's Super Space Invaders (1991)
  • Task Force 1942 (1992)
  • Team Suzuki (1991)
  • Teenage Mutant Ninja Turtles - Manhattan Missions (1991)
  • Tempest 2000 (1996)
  • Terminator 2029, The - Deluxe CD Edition (1994)
  • Terminator 2 - Judgement Day - Chess Wars (1993)
  • Terminator 2 - Judgment Day (1991)
  • Terminator, The - Rampage (1993)
  • Test Drive III The Passion (1990)
  • Tetris Classic (1992)
  • Theatre of Death (1994)
  • Thunderhawk AH-73M (1992)
  • Time Paradox (1996)
  • Timequest (1991)
  • Tongue of the Fatman (1989)
  • Tony La Russa Baseball II (1993)
  • Top Gun Danger Zone (1991)
  • Tornado (1993)
  • Tornado Operation Desert Storm (1994)
  • Tough Guy (1994)
  • Toyota Celica GT Rally (1992)
  • Transport Tycoon (1994)
  • Transport Tycoon Deluxe (1995)
  • Treehouse, The (1991)
  • Troddlers (1993)
  • Trog! (1990)
  • Troika (1991)
  • Trump Castle 3 (1993)
  • TV Sports - Baseball (1990)
  • TV Sports - Boxing (1991)
  • Twilight - 2000 (1991)
  • Tyrian (1995)
  • Tyrian 2000 (1999)
  • Ultima III - Exodus (1983)
  • Ultima IV - Quest of the Avatar (1985)
  • Ultima VI - The False Prophet (1990)
  • Ultima Worlds of Adventure 2 - Martian Dreams (1991)
  • Ultrabots (1993)
  • Undersea Adventure (1994)
  • Unnecessary Roughness '95 (1994)
  • Vaxine (1990)
  • Veil of Darkness (1993)
  • Vengeance of Excalibur (1991)
  • Viper (1994)
  • Viz - The Game (1992)
  • Wacky Funsters! The Geekwad's Guide to Gaming (1992)
  • War Diary (1997)
  • War in the Gulf (1993)
  • WaxWorks (1992)
  • Wayne Gretzky Hockey 3 (1992)
  • Waynes World (1993)
  • Where in America's Past is Carmen Sandiego (1991)
  • Where in Space is Carmen Sandiego (1993)
  • Where in the USA is Carmen Sandiego Deluxe (1994)
  • Where in the World is Carmen Sandiego CD (1995)
  • Whizz (1994)
  • Wild Wheels (1990)
  • Wing Commander III Heart of the Tiger (1994)
  • Wing Nuts - Battle in the Sky (1997)
  • World Circuit (1992)
  • Worlds of Ultima - The Savage Empire (1990)
  • World Tour Tennis (1993)
  • WWF Wrestlemania (1992)
  • Xenocide (1990)
  • XF5700 Mantis Experimental Fighter (1992)
  • Xi You Ji (1994)
  • Xmas Carnage (1994)
  • Yumemi (1995)
  • Zeliard (1990)
  • Zis the Adventure (1995)
  • Zone 66 (1993)
  • Zool (1993)
  • Zorro (1995)
Reply 18 of 42, by Spikey
krcroft, thanks for your original share. Might be better to put these into text files you link to, rather than paste into the forum, though?
Anyway, on your original share, one point of clarification: Incredible Machine 1 and 2 are GM games, not MT-32. I am impressed that all the other Sierra games you had identified correctly as MT-32 or GM/SC-55! 😀 Especially PQ1VGA, which people get confused with all the time (see: this thread).
Reply 19 of 42, by krcroft
Spikey, thanks for reviewing the list so carefully and suggesting I use GM for my Incredible Machine configurations. (another reason to play those again!).
Maxtherabbit, I'm happy to collapse my posts to txt attachments if you think it will improve the thread.
(I do find attachments useful for bulk material tangential to the topic, but because these lists are nicely formatted and directly address OPs question, I figured the content placement is warranted. Also, guests can see the content and not have to sign up to download it as an attachment)
