First post, by FSOD
I picked up a japanese SC-55mkII and it came with an AC adapter and every thing. I know I can just plug it in and it would probably in general be ok but I dunno about running 120v through a 100v AC adapter long term. Can I just use an american SC-55 AC adapter instead? I was just thinking that would be more convenient then a step down converter. Back of the unit just says DC in 9v 600mA. Sorry if this is a stupid question.
Reply 1 of 6, by derSammler
Yes, since the SC-55 only ever see the secondary voltage anyway. But you can also run the Japanese AC adapter with 120v. It's a transformer-based PSU, so it will probably output 10.8v in that case. The SC-55 however won't care, since all the voltage regulation happens inside the unit and that works with anything between 7v and 12v.
Reply 2 of 6, by FSOD
oh ok cool. so no real risk of using the japanese AC adapter it came with? I was just gonna buy an additional american one but if there really isnt any risk then I won't bother.
Reply 5 of 6, by CrossBow777
Yeah I actually use my JPN PSU with my JPN TurboDUO and have for years without any issue. The adapter gets a bit warmer than it likely would have normally and I ended up replacing the VRs inside that console with DC-DC switching converters so heat isn't a problem either. But to answer your question, you can use an US PSU with the JPN SC-55 without issue. In fact I'm using a Sega Genesis model 1 PSU with my JPN Edirol SD-20. I do have the original JPN PSU for it, but knew a spare Genesis adapter would work fine and opted to go that route.
Midi Modules: MT-32 (OLD), MT-200, MT-300, MT-90S, MT-90U, SD-20
Reply 6 of 6, by FSOD
yea I use model 1 genesis plug for my top loading famicom and that works pretty good. I knew in alot of cases it was pretty safe but I'm an idiot and wanted to make sure.
