First post, by PiperTheGreat
Hello all,
First time posting here, although have often perused this site for advice, but now I need to pick your brains, as I have no idea what to do
I am trying to install drivers for a Sound Blaster Live! on a Windows 98 machine I built. Had several issues along the way, but most seem to be fixed now, but I keep bumping up against the same one now.
Whenever I install the driver, it runs through its process of what I presume to be installing things and actually doing something useful behind the scenes, but after it tells me to restart and the system does, I boot up with absolutely no difference, it's like nothing has happened. All I get in device manager is Creative Multimedia interface.
I got the drivers from the Creative site, and also some drivers that claim to be "Web" drivers. These are even worse.... they claim that there isn't a relevant card installed......
I don't know what I'm doing wrong, system has been wiped and currently, there is nothing on there, I just want to get these working first
I know that the SB0220 is a Dell OEM variant, is it purely that, and is there NO way to get it working on a non Dell system? I hope I don't have to get a new card, had hoped to get this one working
Any help would be appreciated, thanks!
Steven
Reply 1 of 11, by gdjacobs
The stock Live 5.1 drivers don't necessarily have the PCI IDs of the 0220 in the INF file. What OS do you need drivers for?
Reply 4 of 11, by PiperTheGreat
gdjacobs wrote on 2020-01-11, 05:56:
Specifically, I need drivers for Windows 98SE. The Creative site suggested it had them, they’re the ones I tried
kolderman wrote on 2020-01-11, 06:04:
Via chipset motherboard?
Yes! How did you guess? Haha
elmeyer wrote on 2020-01-11, 08:13:
Ah, thank you. Let me get this straight…. The drivers on the creative site, are just a supplement to the original drivers that you MUST use, that came on a disc?
Reply 5 of 11, by elmeyer
The drivers on Creative‘s site are only for retail cards, I believe. They are definitely newer, though. Due to the missing IDs for OEM cards I don’t believe you can use them for an upgrade, however...
Reply 6 of 11, by kolderman
Because they are mostly not compatible with the Live! and there is a good chance it won't work regardless of diver version.
I had the same problem, also with Audigy, need to bump up to Audigy2 to get a working build with that chipset.
Reply 8 of 11, by gdjacobs
Yup, use the Win98 drivers from Vogons. For Win2k or XP, use the following drivers from Dell:
https://www.dell.com/support/home/ca/en/cadhs … driverid=r69382
Reply 10 of 11, by Lazar81
Hello ... Sry to bring that up again.
I tried to install a sb0220 in Windows XP. I tried different drivers mentioned here on vogons. I also tried to install with the original disc that came with the card... Nothing worked. It always tells me, that there is no soundblaster installed in my system.
When I take a look in the device manager it tells me that there are indeed devices of the card installed. But not the audio device.
Shall I just sell this card ... I don't want to... I really want to try it. But how... If drivers are not installing because Installation program can't find the card. Any help is appreciated...
Ryzen 5 2600X - ASUS ROG STRIX X470-F Gaming - 32GB RAM - Nvidia GeForce GTX 1080 Ti
Reply 11 of 11, by Lazar81
Hello...
I really found a way... 😀
Just in case someone is in search for working windows XP driver that don't drive you crazy - this is what you are searching for:
https://www.driverguide.com/driver/detail.php … driverid=487162
